crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
This wiki is to address common problems with the Tengda S5+ and list potential solutions.
Speakers Crackle
Phone's speakers make a crackling sound when used.
Volume too high
Listening to audio at higher volumes can cause the speakers to emit a crackling sound. Lower the volume on the device to fix this problem.
Water damage
If your phone has recently been exposed to or dropped into water, this may have damaged the speakers. Water damage will require that the speakers be replaced. Use the Speakers Replacement Guide for assistance.
Defective speakers
Sometimes the speakers make this noise without any apparent reason. If so, the speakers may be defective and need to be replaced. Use the Speakers Replacement Guide for assistance.
"No SIM Card" Error
When I turn on my phone, I get a SIM Card Error.
Loose SIM Card
This may be caused by the SIM Card being to loose in it's housing. This can be fixed by turning off the phone and resecuring the SIM card located under the back case and above the battery. Use the Battery Replacement Guide to gain access to the SIM card.
Dirty SIM Card
A SIM Card error may be caused by a dirty SIM card. This can be fixed by turning off the phone and removing the SIM card located under the back case and above the battery. Use the Battery Replacement Guide to gain access to the SIM card. Wipe the connection points on the SIM Card with a dry microfiber cloth before placing in it back in the phone (do NOT use water).
Incorrect SIM Card
SIM Card errors may also be caused by using the wrong type of SIM card for your phone. Check your phone's owner manual to find out what kind of SIM card your phone requires. You can also check the Tengda S5+ device page here.
Phone won't charge
I plug my phone into the charger, but it doesn't charge.
The Charger is Incompatible
The phone will not charge if the correct charger is not used. Check the phone's owners manual or the Tengda S5+ device page to see what kind of charger is needed.
The Charger is Damaged
Sometimes the charger may be damaged. Try charging the phone with a different charger or replacing the broken one.
Home button is unresponsive
When I press the Home Button, it doesn't work.
The button is dirty
A dirty home button can cause it to be unresponsive. To solve this problem, follow the Home Button Replacement Guide to gain access to the home button and clean any dirt away.
Battery won't hold charge
After I charge my phone, the battery dies quickly.
Old Battery
The battery in your phone may be too old. Old batteries lose their ability to hold charge and will require a battery replacement. Follow the Battery Replacement Guide for assistance.
Damaged Battery
If your phone has received any damage lately, this might have also damaged the battery. Damaged batteries will need to be replaced. Follow the Battery Replacement Guide for assistance.
Overcharged Battery
Another cause of a quickly dying battery is overcharging. This occurs when you leave your phone charging overnight or for long periods of time. Next time you charge your phone, only leave it charging until your phone is fully charged.
Sean Downey
crwdns2935283:004/23/15crwdne2935283:0
348 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 14-9, Amido Spring 2015 crwdns2935289:0Cal Poly, Team 14-9, Amido Spring 2015crwdne2935289:0
CPSU-AMIDO-S15S14G9
crwdns2936753:030crwdne2936753:0 54
crwdns2959996:0crwdne2959996:0 1,011
