Why do TVs have backlights?
To answer this, we need to understand a little about how a TV makes its image
A TV makes a self-luminous image. A flat panel TV makes this image using one of two basic ways, commonly known as OLED and LCD. Confusingly, both types use LEDs to make the light for the image, and some LCD displays are called LED displays. We will concentrate on the LCD displays and let the OLED types go.
The LCD display uses white LED backlights to provide light that the LCD matrix then modulates. The liquid crystal (hence the LC of LCD) in this display is formed into tiny pixels or dots. These have electronically controlled color filters that regulate the color and brightness of the light.
But the starting place is the backlight—no backlight—no image.
LCD Display Backlight Architecture
  • Many backlights in TVs with an LCD have strips of multiple LEDs behind the LCD. (there are TVs that have LEDs around the edge of the screen.)
  • The LEDs on these strips have lenses which serve to spread ot the light they produce.
  • Generally the backlight circuit with these LED strips is fed a constant current at whatever voltage is needed.
    • Brightness is increased by increasing the level of the constant current (which causes more heat to be generated in the LEDs).
What Causes TV Backlight to Fail?
Heat is the leading cause of backlight failure. What fails and the consequences of the failure can vary.
The failure of one LED on a strip might create a slightly dim area on the screen. When a more serious failure occurs, such as multiple LEDs failing and becoming short circuits, the power supply will shut down because it will overheat.
If an LED fails as an open circuit, then the entire backlight will usually stop working.
LEDs are arranged differently on different TVs so that some failures may affect a specific TV differently. You can test the strips to find out what has failed.
Heat is the great enemy of virtually all electronic components and backlights are no exception. More heat—more failures.
Some Common Causes and Consequences
Backlight brightness settings
Keeping the brightness turned up constantly, especially to 100%, will increase failures in the LEDs from heat generation. This is the single worst thing you can do to your TV. Also, TV’s that are on 24/7 are more prone to failure because of long term heating.
Backlight strip component failure
Over time, components like resistors, capacitors, and diodes on the strip will degrade because of the heat produced by the LEDs. When they fail, they frequently damage the LED strip irreparably, such as causing burnt areas on it.
Backlight lens failure
Associated with the heat failures mentioned above, the lenses that spread the light from each LED can fall off. This is usually caused by excessive heat, which melts the adhesive holding them to the strip. This will cause a bright spot on the screen instead of a darker area.
The lenses can be reglued in place. This process requires a means to perfectly place the lens to reglue it, or the light will not be spread evenly. A new strip (or strips) may be a better choice.
Diagnosing a Backlight Failure
  1. Backlight failures usually cause dark areas, which are most noticeable when the image is dark because you will see a darker spot on the screen. The lit portions will bleed through light, but where the LEDs are not working, the screen will be darker.
  2. Lens Failures will cause bright spots while the area remains lit, although perhaps a bit dimmed.
  3. Edge-lit TVs aren’t as common, and failures in those units often show up as a dark half-screen.
  4. If the screen will not light at all in any portion:
    1. you may have a power supply failure (uncommon), or
    2. you may have a sufficient number of failed LEDs or other components on the strips that the power supply shuts down.
Repairing a Backlight Failure
Many backlight failures are repairable. Once the damaged component is identified, it can be replaced.
If the backlights or anything on the backlight strips are the problem, replace ALL the backlights, especially if there is more than one failure. Backlight strip kits cost around $30-60US, which is considerably less than a new TV.  It’s kind of like headlights on a car, if one burns out, the other one will probably follow soon. So do them all.
Follow this Samsung Television Backlight Replacement guide for more details.
Additional Resources
Here is a good video by a reputable author with some valuable diagnostic information
Max Bennett
crwdns2935283:006/04/21crwdne2935283:0
2.846 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Staff
crwdns2931471:0123crwdne2931471:0
crwdns2935297:085.988crwdne2935297:0
crwdns2944067:018crwdne2944067:0
On my Hisense Roku tv my screen is black but the red power light still works so power is on what do I do?
Alvinryanjameson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Replace the backlight driver capacitors. These will be near where the LED strips plug into the main PCB and will be of a higher voltage value like 100uF @ 100v or something. These caps see alot of load and heat if the TV set is used alot. They go out of spec and cause the backlight power supply not to function or they cannot hold capacity to drive the LEDs. The factor stock caps tend to be cheap and low tier so you want to replace with a better quality like nichicon and get the correct uF value but you can get higher voltage just not lower voltage that what is there already.
Adriel Elfnet (ENCI) - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Actually the LED backlights operate anywhere from 12 - 72 volts with several backlight strips in series on one or more power channels with current limitation. Also some use PWM to adjust brightness with changes in the program image on screen. Each LED on a strip will have a lens over it that directs the light back onto a white backing instead of straight out in front.
Dead LED TV sets LED strips can be repurposed to be used as 12 volt LED lighting for backup power, in RV and campers, in a vehicle, etc. Typical each LED on a strip are 3.2 - 3.8 volts, however in some bigger TV sets (60+ inches) each LED can be 4.5 - 7.2 volts. So if you know how to use a soldering iron and how to cut & modify the traces on the strips you can repurpose the LED strips in that dead TV set.
crwdns2936751:024crwdne2936751:0 46
crwdns2936753:07crwdne2936753:0 298
crwdns2936753:030crwdne2936753:0 1,217
crwdns2942667:0crwdne2942667:0 70,346
