crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Flashing Led Lights
A green light will blink after you turn your SwagTron on.
SwagTron Not Calibrated
The hoverboard could not be calibrated correctly. To calibrate the hoverboard, power it off first. Place it on a flat surface and ensure both sides are level as well (you can use a carpenter's level to be precise). Hold down the power button for 10 seconds and you should hear a beep, and led lights should start flashing. Once they do, press the power button again so that the SwagTron is off. Turn it back on, and your SwagTron should be calibrated.
Broken Wheel/Wheels
Four blinks of the led means the wheel opposite the side the battery is on is damaged and needs to be replaced. If there are five blinks, then the wheel on the same side of the battery needs to be replaced. Here is a replacement guide on how to replace a damaged wheel.
Damaged Gyroscope
Seven or eight flashes of the LED indicate that the gyroscope inside the hoverboard is defective or damaged, and may need to be replaced. Here is a guide on how to replace the gyroscope.
SwagTron Won’t Turn On
You press the power button over and over but your SwagTron never turns on.
Battery Not Charged
Your SwagTron has a Li-Ion battery inside that has to be recharged. Plug your SwagTron into the charger for 2-3 hours and it should be fully charged and ready to ride. If you don’t have a charger, you can buy one here.
SwagTron Won’t Charge
You plug your SwagTron into the charger for hours, but it never charges the battery.
Broken Charger
Your charger may be broken or faulty, you will need to buy a new charger here.
Dead Li-Ion Battery
Your SwagTron has a Li-Ion battery inside that over time loses its “juice” and is no longer able to power your hoverboard. Here is a guide on how to replace that battery and keep riding.
SwagTron Balance is Off
My SwagTron is not responding to my movements the way it should be.
Hoverboard not calibrated
The hoverboard could not be calibrated correctly. To calibrate the hoverboard, power it off first. Place it on a level surface and hold down the power button for 10 seconds and you should hear a beep. Led lights should start flashing, and once they do you should go ahead and press the power button so that the SwagTron is off. Once you turn it on, your SwagTron should be calibrated.
SwagTron is Not in Self-balancing Mode
The SwagTron has an automatic self-balancing mode when it is turned on. To make sure the self-balancing mode is on, move the hoverboard to a flat area and wait a few minutes. After a few minutes stand on the hoverboard with two feet and make sure that there are no other objects that could possibly unbalance the board. Always try and avoid riding the hoverboard sideways and turning on slopes because doing so can cause the self-balancing sensors to be defective.
Damaged Gyroscope
If the board does not balance properly, the gyroscope inside the board could be damaged and would need to be replaced. Here is a guide on how to replace the gyroscope.
SwagTron is Slow
No matter how hard you try to speed up… your swagtron…. Goes at the pace of a turtle….
Learning Mode
The SwagTron has a “learning mode” to help beginners get used to using it before going at higher speeds. You can switch from the learning mode to performance mode by first turning your SwagTron off. Then press the power button 1 time to turn it on and then press it again 1 second later to switch modes. You should hear a longer beep on the second press.
Teagan Allen
crwdns2935283:004/18/17crwdne2935283:0
432 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S17-G5, Banghart Spring 2017 crwdns2935289:0Cal Poly, Team S17-G5, Banghart Spring 2017crwdne2935289:0
CPSU-BANGHART-S17S17G5
crwdns2944067:053crwdne2944067:0
Turn on the swagtron and battery light flashes and it's beeping the entire time. It does still function very sensitive to movement tried to calibrate ,charge,and self balancing by the manual . What could I do to fix my daughter's birthday gift she has only rode once ?
Steven stallons - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hold power button longer then 10sec..more like 30 then pwr off then on.
dick tracey - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My brother got a swagtron kids hoverboard for christmas after 2 weeks everytime he turns it on it constantly beeps and has the red arrows blinking. I tried to re calibrate it many times and it still wont stop blinking or beeping. Help please.
Savannah Piehs - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Indians, who are the fan of [|Swagtron hoverboards] have the Good News. Now, Swagtron hoverboards is also available in India. We are distributors of Swagtron from India. Click here to purchase your hoverboard online: [|https://swagtron.in/]
Avani Vyas - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
When I step on my hoverboard, it flashes and beeps. Nothing else. It won’t turn, move, or stop flashing that red circle. I already tried to collaborate it but it failed to work. How do I fix this? It was only opened for 4 days!
A person - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 86
crwdns2959996:0crwdne2959996:0 81,074
