crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Camera Does Not Turn On
The camera fails to turn on, even after the battery is determined to function properly.
Battery Not Charged
It is possible that the camera’s battery was not charged. To remedy this, plug the camera’s battery into the charger, and ensure that the plug is securely and entirely plugged into an outlet.
Faulty Battery
If the camera does not turn on, even after an attempt to charge the battery, it is more than likely possible that the battery has completely failed and will require replacement. To replace the battery, remove the battery block from its housing, and insert a replacement battery into the old battery’s location. Attempt to power on the camera. For further reference, please see our replacement guide on how to replace a faulty battery.
Defective Motherboard
The Sony a7 is equipped with a central motherboard that controls most of the camera processes. The motherboard is located inside the camera housing. A more comprehensive teardown will be necessary to address any issues with the motherboard itself. For further reference, please see our replacement guide on how to address a faulty motherboard.
Camera Screen Does Not Function
The camera’s rear display fails to light up, display pictures, or allow interaction with the menu.
Faulty Battery
Dirty Or Obstructed LCD Screen
Ensure that the rear-facing camera screen is clear of all foreign objects by using an approved cleaning solution and cloth to clean off the surface. Contaminants and debris may have hindered the ability to view the Liquid Crystal Display screen (LCD) fully.
LCD Screen Failure
Once it has been determined that the screen had not been obscured by any vision obstructing objects, it is possible that the Liquid Crystal Display Screen (LCD) has failed, which will require further action as the screen will need to be replaced. For further reference, please see our replacement guide on how to replace a faulty LCD screen.
Battery Door Will Not Close
The camera battery door assembly does not move or is jammed in a manner to prevent movement.
Faulty Battery
Battery Door Assembly Jammed
Once determined that the battery is not the source of the issue, analyze the battery door assembly. Disassemble, and ensure that the joints are properly lubricated, and there are no obstructions that could prevent the smooth flow of the opening and closing motion.
Camera Unable To Connect To Computer
The camera is unable to show a proper connection when plugged into a computer, and it cannot download photos.
Loose Display Connector
Try unplugging the USB prong from the camera and checking to make sure that the right plug is being used to connect to the computer. Once verified, check the computer’s external device settings to ensure that no security restrictions are blocking the port from being read. Restart the computer and refresh all relevant data and folders about the camera’s files.
Broken Camera AV Port
If all other options fail to yield an effective result, it may be possible that the camera’s AV port itself has failed. This would require a full-scale breakdown of the camera to access the part and the repairing or replacement of the part with another. For further reference, please see our replacement guide on how to repair the AV port.
Shutter Door Is Inoperative
The camera’s shutter door fails to deploy in an open or closed position on a proper cycle.
Dirty Or Obstructed Lens
Using an approved cleaning solution and a microfiber cloth, ensure that the lens and housing section that surrounds and protects the lens is fully cleaned off, and free of any debris. Foreign contaminant buildup in the area could cause the shutter door to fail, and improperly follow the programmed cycle.
Damaged Lens Assembly
If the shutter problem persists, the next course of action would be to replace the lens assembly. Other attempts to fix the shutter door unit would be tedious, costly, and could void any warranty. The shutter door failure is a common enough occurrence that the lens assembly can be acquired and replaced. For further reference, please see our replacement guide on how to replace the lens assembly.
Jeffrey Coleman
crwdns2935283:001/14/20crwdne2935283:0
1,364 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S16-G2, Branham Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S16-G2, Branham Spring 2020crwdne2935289:0
ERAU-BRANHAM-S20S16G2
crwdns2944067:05crwdne2944067:0
Dopped camera. It switches on and takes pictures but no other button or dial pressing function works.
Jide - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Tengo el mismo problema, por favor si tiene la solución me escribes a mezagallego@gmail.com
Mil gracias
Leonardo meza gallego - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The date resetted when I swap battery. How to fix this?
Jamal Hossain - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
red led lights up timely always while not turn it on, since last time i drop some deionized water over the cmos glasses and pull it clean. it is going bad while i start to discover, it can not be restarted again, i have no choice but to put it in the dlsr container box for dry it over as the final try which i can only offer.
雁峰 陶 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 118
crwdns2942667:0crwdne2942667:0 11,129
