The Sony Ericsson z300 is an upgrade of the z200 with smaller dimensions and an internal antenna. It is a basic phone for users who only need to make basic phone calls or texts.
Note: This troubleshooting page covers the Sony Ericsson z300.
Phone Won't Turn On
Phone screen stays blank when power button is pressed.
Battery is not Charged
Try charging the phone to make sure the battery has some charge in it.
Faulty Charging Cable
If the phone is plugged in and not charging, the charging cable may be faulty. If this is the case try borrowing a cable from someone who has the same phone or try buying a new one.
Battery is Dead
If the battery won't hold a charge and the charging cable is still good, then the battery is dead and may need to be replaced. This is a common ailment with older rechargeable batteries. Refer to the Sony Ericsson z300 Battery Replacement guide for help with removing the battery.
Bad Motherboard
If the above steps don't fix your problem the motherboard may need to be replaced. You may want to contact your nearest Cingular/at&t store to fix this problem, otherwise you will need to replace the motherboard yourself. Refer to the Sony Ericsson z300 Motherboard Replacement guide for help with removing the motherboard.
Phone's Screen is Broken
Either the screen has visible cracks in it or the interior of the screen maybe be broken causing the display to appear to be bleeding behind the glass.
External/Internal Screen
If the screen lights up but does not show any detail or has visible cracks in it, the screen may need to be replaced. For help with removing the screen refer to the Sony Ericsson z300 Screens Replacement guide.
User is Unable to Hear Anything
While making a phone call the user cannot hear the person on the other end of the line
Volume
Make sure that the in call volume is up.
Headphone Jack
Make sure the headphone jack is clear, as this may cause the phone to think there is a headset plugged in and not transmit any audio to the phone speakers.
Software
The phone may need a basic reset. While the phone is on remove the battery for thirty seconds and then reinsert the battery. This should complete a basic software reset, without loosing any contact information.
Broken Speaker
If all these fail, the front speaker may be broken and may need replacing. For help with removing the speaker refer to the Sony Ericsson z300 Front Speaker Replacement guide. If the front speaker is working properly and it is the back speaker that isn't working, the Sony Ericsson z300 Back Speaker Replacement will help with the removal of the back speaker.
Buttons Won't Work
Nothing happens when buttons are pressed.
Broken Keypad
Either the keypad is broken and will need to be replaced or the Motherboard may be bad and need to be replaced. Refer to the Sony Ericsson z300 Keypad Replacement guide for help with removing the keypad. Refer to the Sony Ericsson z300 Motherboard Replacement guide for help with removing the motherboard.
External/Volume Control Light is Broken
Light won't turn on when supposed to.
Light stays on even when phone is off.
Software
Alex Serventi
crwdns2935283:010/07/10crwdne2935283:0
65 crwdns2915208:0crwdne2915208:0
crwdns2935297:013crwdne2935297:0
Cal Poly, Team 5-15, Maness Fall 2010 crwdns2935289:0Cal Poly, Team 5-15, Maness Fall 2010crwdne2935289:0
CPSU-MANESS-F10S5G15
crwdns2935297:0156crwdne2935297:0
my phone will turn on and it will say sony ericssion and then it will say android and that's it it will not fully turn on...HELP!!!
Shanquella - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 4,322
