Trouble Reading a Disc
You place a disc in the player and it doesn't work.
The Disc is Dirty
Inspect the disc for dust, finger prints, or other material. The disc can be cleaned easily by using a dry microfiber cloth to wipe off anything on the disc. If needed, you can wet the disc with a very lightly damp cloth to help remove the material on the disc.
The Disc is Scratched
If you can see visible scratches on the disc, you can try to clean the disc just like in the previous paragraph. Another option is to use a disc repair machine. These machines attempt to fill in the scratches so that the disc can work again.This may help but ultimately if the disc is damaged there is not much that can be done besides buying a new disc to replace it.
Laser is Faulty
Inside the blu-ray player is a blue laser that reads the data off of the disc. If this laser is not working for one reason or another, it will not be able to read any disc you try to play. The first step worth a try is to use a microfiber cloth to try to clean off the laser, as dust might be blocking the laser light. The second step would be to actually replace the laser.
Disc Drive is Broken
One problem with the disc drive is the loading tray not opening. Another problem could be that the blu-ray player is not spinning the disc. These problems are a mechanical problem inside the disc drive and may be fixable, but would require disassembling and careful inspection of the drive. The disc drive can also be replaced if a fix is not possible. Be sure to check out the repair guides here.
The Device is Overheating
Each time you use you Blu-Ray, it becomes too hot.
Poor Ventilation to the Device
It is recommended to keep the blu-ray player in an open area where there is plenty of air flow to keep the system cool. Do not block or cover the openings in the device. Also, if the blu-ray is placed in a confined area, such as a cabinet, make sure that the device will stay cool with appropriate ventilation.
Internal Fan is not Working Properly
Inside the system, there should be a fan that keeps the system from getting too warm. Even though the fan isn't too loud, you should be able to hear it when the device is running. If you cannot hear the fan when the blu-ray is on, then it might be broken and you will have to disassemble the device to replace or fix the fan. To do so, you can consult our repair guide to replace the fan here.
Excess Dust Inside the System
If you check the vents and find that there is a lot of dust trapped inside, try cleaning it out using a rag or towel to allow for better air flow to your system.
The Device Freezes
An image is stuck on the screen and will not change when you try pressing other buttons on the remote or player.
Common Solution
Usually if an electronic device malfunctions, the best solution might just be to reboot the system. Hold down the power button for more than five seconds and wait until it shuts down completely before starting it back up. A simple restart might be able to kick the player back on track and fix the problem.
Problem with the Disk
If you find that your player freezes frequently with the same disc, check to make sure your disc is clean and free of any scratches. If so, wipe the disk with a clean microfiber cloth.
Problem with the System
If either of the first two options do not stop the Blu-Ray player from freezing, there might be a problem internally. In such a case, you would need to safely disassemble the product and inspect the different components to make sure nothing is missing or damaged.
No Video
"No image is appearing on the screen. What gives?"
Plugged in
Ensure that the device is plugged in and turned on and that the cable you have selected is connected to the TV. When using an HDMI cable the HDMI indicator light should light up.
Correct Input/Video
Ensure that you have your TV set to the correct input. Your TV maybe have more than one HDMI input so be sure to check every HDMI input.
Broken Cable
If you still can't get an image, try using the cable on a different device or using a cable you know works on this player. If the cable doesn't work on a different device, you probably need a new cable.
Broken Output
The output on the player may be broken so you will need to replace this.
Poor Video Quality
You're watching your favorite movie and you notice that the quality of the video is horrible and grainy. What's the deal?
It may be the movie itself
The problem may not even be the player itself. Many movies have post-processing effects that make the film look grainy. This is to give it a more "movie-like" feel. If you know for a fact that the movie is not meant to look grainy, then please continue on.
Check the Cables
Often times, an issue is caused by the simplest problems. Check to see if all the cables in the back are properly connected. If you're using the HDMI cable, make sure it's plugged in completely on both sides. If you're using the RC cables (red and white), check if they are correctly plugged in (red goes in red, white goes in white). HDMI cables provide better quality, so if you're using RC cables, try upgrading.
Make Sure Your TV Supports 1080p Resolution
Not all televisions support high-quality 1080p resolution. Many only support 720p which would be a cause for poor video quality. Some televisions have a sticker on them indicating what resolution they support. Otherwise, you can look up the name and/or model number of the TV online and see if it supports 1080p.
Connecting to a VCR
Connecting to a VCR that is connected to the TV may prevent you from receiving a clear image. Make sure you connect the blu-ray player directly to the TV to avoid this.
Low Quality
You can further configure your video quality by pressing the VIDEO FORMAT button on the front panel and adjusting resolution from there. Some Blu-ray disks may also be lower quality than others resulting in differing quality between Blu-ray disks.
Poor Audio Quality
The audio in the movie you're watching sounds like it's hiding behind a wall or there's no sound at all.
Using a HDMI-to-DVI Cable
DVI inputs do not support audio, only video. If you want sound you can connect a HDMI cable from the player to the TV or an analog red/white cable to get sound.
Wrong Video Input
Make sure you have your TV set to the correct input or video. There may be more than one HDMI input on your TV so make sure you set it to the correct one.
Bad HDMI Cable
The HDMI cable might be faulty. If possible check to see if it works with other devices or try a different cable on the player.
Bad HDMI Output
Something is wrong with the HDMI output and it needs to be replaced.
Sam
crwdns2935283:001/26/14crwdne2935283:0
376 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-30, Maness Winter 2014 crwdns2935289:0Cal Poly, Team 9-30, Maness Winter 2014crwdne2935289:0
CPSU-MANESS-W14S9G30
my hdmi output in not accepting the signal.I have been using the RGB instead,I need to fix the hdmi output connection inside the unit………………zebra8488@yahoo.com
gallagher1918 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 2,751
