crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
An Image on the Screen Won’t Go Away
An image, pattern, or text on the screen does not disappear completely, even when I open other applications.
Messed up Display
The Samsung Galaxy Tab S3 has a Super AMOLED (Active-Matrix Organic Light-Emitting Diode) display. The way this display works is that each pixel is composed of an individual light-emitting diode, which is like a very small light bulb.
There are many benefits to this type of display, including:
  • Darker black pixel color
  • Improved color accuracy
  • Efficient power use
  • Ability to run parts of the screen without turning the entire screen on
Unlike LCD, however, AMOLED displays are susceptible to a phenomenon known as “screen burn-in.” What this means is that each of the individual ‘light bulbs’ powering the display will dim the more they are used, causing uneven lighting and colors. This happens more quickly and is more noticeable in areas where static images are displayed for extended periods of time, such as the status bar, keyboard, or video player letterboxing.
You can check for burn-in by downloading a white or light gray solid-color image onto your device, zooming in so it fills the entire screen, and viewing it up close. If you notice certain parts of the screen are noticeably darker or lighter than others, and don’t go away after a long period of time, you have burn-in. Keep in mind that this is different from image retention, which typically disappears in about 15-20 minutes.
Keep in mind that, since burn-in is damage to the display itself, you cannot zoom in or take a screenshot of the affected area. Burn-in does not inhibit the functionality of the tablet, and you can continue using the device as normal. However, if burn-in bothers you, you may want to consider replacing the display assembly.
You can follow the display replacement guide to learn how to replace a broken or worn-out display on your tablet.
The Battery Doesn’t Hold a Charge
The battery fails to hold enough charge to last a full day of use.
Faulty Battery
The Samsung Galaxy Tab S3 has a 6000mAh battery which Samsung rates for 12 hours of use. This is enough battery capacity to last most average users at least a day.
However, as with most electronic devices, the Tab S3 uses a lithium-ion battery; it is normal for lithium-ion batteries to sustain damage after each charge cycle and degrade over time.
You can run a battery utility such as AccuBattery to check the health of your battery. Install the app on your tablet, set it up, and let it run in the background for a few days with normal use. If you check back in the app a few days later, it should be able to accurately tell you how much damage your battery has, what its new capacity is, and how many hours of use you should be able to expect from your tablet.
Most tablet batteries are designed to last about 2 to 3 years before becoming too worn out for normal use. If your battery is more than around 20% damaged, you might want to consider replacing it.
Learn how to replace the Tab S3's battery by following the steps in the battery replacement guide.
The Tablet Won’t Charge
The tablet fails to charge when the cable is plugged in.
Dirty Charging Cable/Port
Sometimes the tablet will not seem to recognize when you insert the charging cable. Other times, the charging cable may not fit all the way in to the tablet, or will easily pop out while charging. If this happens, it is a good indicator that your charging cable is clogged with lint or dirt.
Because they are not kept in pockets, tablets are typically less susceptible to getting a clogged-up charging port. However, the port can still become obstructed with debris when stored in a bag, used outside, or used in a dusty environment.
Luckily, USB-C ports, such as the one found on the Tab S3, are often considered the easiest charging ports to clean, and hailed as the most durable alternative to Apple’s Lightning connector and the older Micro USB standard.
To clean your tablet’s charging port, turn your device off, and use a toothpick or other non-conductive tool to scrape the lint out. You can stick the toothpick in the port and move it in an oval around the center pins until all the lint comes out. Avoid using a metal tool for this task, as it can bend the pins; in a worst-case scenario, it can short-circuit the device, turning a simple cleaning job into a complicated and expensive repair. You can use a can of compressed air to remove any loose debris in the charging port that cannot be removed with the toothpick. When you plug the cable back into the tablet, it should fit nicely, with the plastic around the plug resting flush against the metal frame.
The Physical Buttons on My Tablet Don’t Work
The home, power, and/or volume buttons don’t click when pressed.
Dirty Buttons
Tactile buttons may begin to stick overtime or become less responsive. Pocket lint, dust, or any sort of debris can change the responsiveness of hardware buttons. This type of stuck button usually isn’t mechanically broken, which means it can usually be fixed by cleaning the area around the button.
To clean the area around the buttons, begin by saturating the end of a cotton swab with isopropyl alcohol. Shake the swab to ensure it is not dripping. Make sure the device is turned off, and then clean around the button, doing your best to work the fibers into the crevices. Let the area dry and try blowing compressed air around the button to remove any additional debris.
If the above cleaning method does not work, then there is a chance that the button is mechanically broken and will require replacement.
My Camera Takes Blurry Photos
The tablet’s camera won’t focus, and all my photos turn out blurry.
Scratched Camera Lens
Tablets are typically less susceptible to getting scratches on the camera lens. However, the lens can still become damaged when used on a table or in an outdoor environment. If you notice that the camera lens is scratched, you may need to replace the glass back of the tablet, as the lens is connected to the back of the tablet.
Protective Film On Camera Lens
The Tab S3 comes with a thin plastic cover on the camera lens. Make sure to remove the small piece of film before taking any photos, since the plastic is less transparent than glass and can affect the quality of your photos.
Fingerprints on Camera Lens
The camera lens may have grease or fingerprints on it, especially after holding the device in landscape mode. Newer versions of the camera app may be able to detect when the lens is dirty and prompt you to clean it when you open the app, but this may not always be the case. To clean the lens, simply wipe the oil off with a glasses cleaning cloth, shirt, or other similar object.
Fogged Lens
Many camera lens fog up in high humidity areas. Use a microfiber cloth to clean the lens before taking photos.
Camera Will Not Focus
Try focusing on a different object by tapping it on the screen. If the camera continues to adjust the focus, tap and hold on the area you wish to focus, and the focus will be locked until you manually focus somewhere else.
Just like if you tried to stare at an object too closely, the Tab S3’s camera will be unable to focus on objects that are too close. Try moving the camera backwards until you are able to clearly focus on the subject, then zoom in or crop the image to achieve the desired effect.
If you find that you need to replace either of the Tab S3's camera modules, you can follow the instructions in the camera replacement guide.
My Tablet Won’t Play Sound
The tablet won’t play audio correctly through the built-in speakers or headphones.
Muffled Speakers
Remember, many problems with software audio drivers can be resolved simply by restarting your device. If the problem persists it is likely a hardware issue.
The Tab S3 has four speakers which provide stereo sound; there are two on the top and two on the bottom.
The speakers face outwards from the metal frame, be careful since you might be covering up the speakers with your hands while using the tablet, especially in landscape orientation
If you still cannot hear sound out of the speakers they might need to be replaced
Follow the speaker replacement guide to learn how to replace one or more faulty speaker modules.
Clogged Headphone Jack
One reason why you may not be able to hear sound coming out of your headphones is because the headphones are broken and not the jack itself. Try listening to audio with another pair of headphones or speakers, and if the problem persists it is likely a problem with the Tab S3’s headphone jack.
If you are a constant headphone user, the jack can get worn out over time or clogged with lint/debris in a similar manner to the charging connector (Battery and Charging).
Try cleaning out the jack with a toothpick.
If it still doesn’t work, you may need to replace the device’s headphone jack. Steps for replacing the headphone jack can be found on the headphone jack replacement guide.
You can avoid future issues with headphone jack failure by using wireless headphones or the built-in speakers.
Mimi Rose
crwdns2935283:004/18/18crwdne2935283:0
684 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S22-G4, Maness Spring 2018 crwdns2935289:0Cal Poly, Team S22-G4, Maness Spring 2018crwdne2935289:0
CPSU-MANESS-S18S22G4
crwdns2944067:015crwdne2944067:0
Help me I bought tablet and person I bought it from I can't get ahold of to remove Gmail and I forgot the password I guess. Please help is this just going to be an expensive brick tablet? I hope not thank you
time4u2nvllc - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My tablet heats up in one corner next to the power button. It gets up to 35 degrees centigrade. This is almost burning my fingers. I am told this is normal. However I have had this tablet since June 2018 and it has only just started doing this. Is anyone else experiencing this or is it as I thought, mine is a lemon as this is the third issue I have had with the screen.
Sandy Lack - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I would think that there is a internal problem. I've had mine for two years and it has never heated up on me.
Country Life - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have the SM t820, will not let me charge, says to check the charger USB port for moisture and to let it dry out. I've tried that multiple times blown it with compressed air nothing seems to work. I even went back to factory reset and that didn't help. Any help would be greatly appreciated.
I forgot I posted this, no one ever answered me. Just an update I changed the charger and the data cable and that fixed my problem.
Kenny d - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 60
crwdns2942667:0crwdne2942667:0 12,540
