Samsung Galaxy Tab S3 Battery Replacement
    1. Samsung Galaxy Tab S3  Battery Replacement, Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
      • Leave the iOpener on edge for two minutes.
      • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
    2. Samsung Galaxy Tab S3  Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place a suction cup near edge that you heated up with the iOpener.
      • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
      • Use an opening tool to split apart the glass panel from the midframe.
      • Be careful to not break the glass when prying from the frame.
    3. Samsung Galaxy Tab S3  Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      Plastic Cards
      $2.99
      • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
      • You can also use multiple opening picks instead of a plastic card.
    4. Samsung Galaxy Tab S3  Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S3  Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S3  Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull off the glass panel using the suction cup.
      • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
      • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
    5. Samsung Galaxy Tab S3  Battery Replacement, Rear glass panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab S3  Battery Replacement, Rear glass panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
    1. Samsung Galaxy Tab S3  Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab S3  Battery Replacement, Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
    2. Samsung Galaxy Tab S3  Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The midframe should snap off from the device’s motherboard.
    3. Samsung Galaxy Tab S3  Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S3  Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy Tab S3  Battery Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
    4. Samsung Galaxy Tab S3  Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab S3  Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
    5. Samsung Galaxy Tab S3  Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy Tab S3  Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
    6. Samsung Galaxy Tab S3  Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The battery should now be removed and detached from the device.
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
crwdns2935229:09crwdne2935229:0
Mimi Rose
crwdns2935283:004/18/18crwdne2935283:0
684 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S22-G4, Maness Spring 2018 crwdns2935289:0Cal Poly, Team S22-G4, Maness Spring 2018crwdne2935289:0
CPSU-MANESS-S18S22G4
crwdns2947412:07crwdne2947412:0
This repair can be done without removing the screen!
hansderaedt - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
how? would it be simpler to do it that way?
Ryan McDaniel - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
There is no reason to remove the screen. It’s super risky to do it that way. When you take the battery out, just use some alcohol on the sides of the battery to weaken the adhesive and use a suction cup to pull the battery out. No need to push on it from the screen side.
Nick Youngstrom - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
What I get for reading a guide before checking comment, TOTALLY unnecessary step in removing screen. LCD cost $220 on ebay….
Phenix City - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Un vrai tuto de merde avec lequel vous êtes assuré de niquer votre tablette !!! Je vous recommande expressément de rechercher sur youtube “ How to Replace Your Samsung Galaxy Tab S3 SM-T825 Battery “ pour trouver un VRAI TUTO simple et qui vous évitera à coup sur de flinguer votre écran.
P de Rochefort
psurbook - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 33
crwdns2936753:030crwdne2936753:0 186
crwdns2942667:0crwdne2942667:0 28,674
