crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Potential Software issues
Before attempting repairs, please make sure that your software is up to date on the camera. If an app on the camera is not working, chances are that others are having the same issue and the developers have fixed the problem.
Camera Won't Turn on
Camera won't turn on, when you press the power button, or it turns off after a short time.
Dead Battery / Short battery life
Fully charge the battery by connecting the camera to a power outlet. You can also remove the battery and charge it with a wall mounted charger. If charging the battery does not help, or the battery does not stay charged, then it might be time for a new battery.
Faulty Power Button
If the battery is fully charged, but the camera still doesn't turn on, the power button might be the cause. Check out this guide to replace the power button.
No Flash
The flash does not pop out, or may not actually flash when you have the flash option turned on.
Low Battery
If the battery is low on the camera, it will try to conserve battery by shutting off the flash. Make sure to fully charge the battery before shooting. It may be advisable to buy an extra battery for all-day shooting.
Burned out Flash
If the camera is fully charged and the flash still won't light up, then perhaps the flash needs to be replaced because of either a burnt out bulb or faulty wiring. Take a look at this guide to replace the flash.
Lens Cover (Shutter) is Stuck
After turning the camera on, the lens does not engage, or the shutter doesn't open fully.
Dirt stuck in Lens cover (Shutter)
If the lens cover won't close or open fully, there may be something stuck between the camera lens and the lens cover. Trying to force it open to take pictures may scratch the lens of the camera. Instead, take a can of compressed air like Blow Off and gently remove the dirt and debris.
Lens Cover (Shutter) wont open on its own
If there is no dirt or debris in-between the lens and the cover, then the cover mechanism might be broken. Check out this guide to fix the lens cover.
Zoom not working
You try to zoom and the zoom button either does not respond, or goes wonky, under or over-zooming.
Dirt in the Mechanism
A thorough cleaning with compressed air or isopropyl alcohol may help to dislodge any debris or clean any dust stuck within the mechanism. Check out this guide for some tips. If this does not work, the mechanism itself may have an issue.
Zoom Mechanism is broken
If a nice cleaning of the assembly does not help the zoom problem, the entire assembly may need to be replaced. It will require a toolkit and you can follow this guide for a little help.
"Zoom Error" pop up message
If you get a pop up message that says "Zoom Error", try following the instructions on screen to solve the problem. If resetting the power source for the camera does not fix the issue, the zoom mechanism of the camera is more than likely malfunctioning or broken. Instead of spending $70 or more for a simple replacement, use this guide to replace it and buy yourself a nice lunch to celebrate.
Screen Won't Turn on
The screen is black, malfunctioning or generally unresponsive.
Dead Battery
Make sure that when you turn on the camera, the battery is charged.
Cracked Screen
When the screen is cracked, an impact may have affected the LCD screen underneath. If the screen is distorted or won't turn on, replace it with the help of this guide.
Motherboard shortages
If the camera was working fine and then was subjected to trauma, such as dropping it in water, the motherboard may have been damaged and no longer be working properly. This may also be the case if the motherboard was defective. You can change out the motherboard with help from this guide.
Camera Will not Take Picture
You are pressing the shutter button, but the camera is not capturing what you see.
Capture Button does not work
If the camera doesn't want to take pictures when the application is open, the capture button may be broken. Check out this guide to help replace it.
Software Issues
If the camera still wont take photos after the replacement, the software on the camera might be malfunctioning. Make sure that the app is up to date- this usually ensures that all known bugs are fixed. Try turning the camera completely off and on to refresh the app. If this still does not work, there might be an issue with the motherboard. Take a look at ourguide to find out how to replace it.
Timothy Proto
crwdns2935283:002/10/16crwdne2935283:0
838 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 14-5, Lacy Spring 2016 crwdns2935289:0USF Tampa, Team 14-5, Lacy Spring 2016crwdne2935289:0
USFT-LACY-S16S14G5
crwdns2944067:09crwdne2944067:0
PLEASE HELP!!!!!!!!!!!
I have the EK-GC200 (Galaxy Cam 2). It worked fine for about a month or so and then while trying to take a picture the display started shaking to the point of making the screen mostly a blur and making a slight grinding noise that sounds like a set of plastic gears slipping teeth. It still zooms in and out fine but shakes constantly making it impossible to take a picture at all. I took it all apart and couldn't see any problems so I ordered a brand new lens module that includes new zoom and focus motors on it and installed it 10 mins ago. The shaking problem has not changed at all. The new lens did not come with the sensor that screws on to the back of the lens module under the dust sticker so i installed the original. IF ANYONE KNOWS WHAT IS WRONG HERE PLEASE HELP!
Thanks,
Jason
Jason - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
also did factory reset and updates
Hello Jason,
I also have the same problem. Did you find a solution?
Ivo M - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
What should I do if logging occurs , it waste time because of slow processing
Cessy Rey - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I love my galaxy 2 camera but it ill not connect and let me use Facebook or any other apps even tho it says it is connected to the internet.
union_mom - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 11,746
