Chromebook Not Charging
First Steps
  1. Check the power connection. If your laptop does not charge while plugged into that outlet, you could have a broken wall outlet. Plug something else into the same outlet. Your outlet is broken if the other device does not get power after these steps. If the other device does get power, try another guide in this section.
  2. Check your power cable and adapter. The power cable might be faulty if the computer does not charge a functional battery. The easiest way to check this is to borrow an identical power cable to test in your laptop. If your battery charges with the borrowed cable, you have a faulty power cable. Purchase a new power adapter at the following link—power Adapter.
  3. Verify Charging Indicator: When you plug in your Chromebook, observe if the charging indicator light (if present) lights up or changes color, as this signifies if the device is receiving power.
  4. Perform a Hard Reset: Perform a hard reset by performing the following steps:
    1. Disconnect the charger from your Chromebook.
    2. Press and hold the power button for at least 10 seconds, then release it.
    3. Reconnect the charger and check if the device starts charging.
If the above steps do not resolve the issue, proceed to the more detailed troubleshooting steps below.
Faulty or Old Battery
  • Check battery level: Plug in your Chromebook for at least 15 minutes, and then check if the charging indicator lights up to show it's charging. If not, the battery might be dead or malfunctioning.
  • Reset the battery: This Chromebook does have a small pinhole reset button on the bottom of the device. Insert a paperclip or a similar tool into the pinhole and press gently to reset the battery.
  • Check the battery's health: Unfortunately, no battery lasts forever. If you've had your Chromebook for a couple of years, there's a good chance the battery is aging. You can look at the in-depth guide for checking your Chromebook's battery health with CROSH, but the process has been outlined below.
    • From your Chromebook's desktop, press Ctrl + Alt + T simultaneously.
    • Enter the command battery_test [<Test Length>].
      • The test length is measured in seconds. If no test length amount is entered, then the default test length of 300 seconds will be used.
      • Specific battery health will be given as soon as the command is entered, but additional information will be given when the test is completed.
  • Replace the battery: It may need to be replaced if it does not charge or hold a charge even after trying the above steps.
If the computer powers up, usually when the power cable is plugged in but turns off when the cable is removed, the battery is most likely disconnected and needs reconnected.
If you have had the computer for over a year, the battery will need to be replaced, as all laptop batteries usually need to be replaced after an extended period. Thankfully, iFixit does feature a guide for replacing your Samsung Series 5 3G Chromebook's Battery.
Faulty Charging Port
If your Chromebook is not charging despite having a proper connection to the charging port, there may be an issue with the charging port, or the cable might be causing the issue.
  • Inspect the Device's Charging Port: Examine the charging port on your Chromebook for any physical damage, debris, or bent pins that may obstruct the charging process.
  • Clean the Charging Port: If you notice any debris or dust in the charging port, use a dust blower or cotton swab with 90% rubbing alcohol to clean it carefully. Ensure that no foreign objects obstruct the connection between the charging cable and the port.
If you see visible damage and cleaning the port has no effect, you may need to replace the Motherboard.
Software or Motherboard Issue
If your device is still not charging, there may be an internal hardware or software issue.
  • Use Google's Chromebook Recovery tool to restore your Chromebook. If your device is experiencing issues with the charger, it may be an issue with the Chromebook's Operating System. If so, look at our guide for creating a ChromeOS recovery USB. Thankfully, the process is straightforward, and creating the Recovery Drive shouldn't take longer than 5 minutes. You can download the tool from the Chrome Web Store.
Note: This will restore your device to the factory default and will delete all files saved to the internal storage, so ensure that any files you want to save are backed up to Google Drive or an external storage device.
  • Perform a thorough visual inspection of the Motherboard. Check for any signs of burnt or damaged components. If you observe any visible damage, the Motherboard must be replaced.
Lines on Chromebook Screen
First Steps
Often it is easy to forget the troubleshooting basics during times of frustration. Before attempting any significant repairs for your device, check the following.
  • Restart your Chromebook. Sometimes, just restarting your device can fix temporary glitches or can clear out any temporary files that might cause issues. You can restart your Chromebook by either clicking on the clock in the bottom-right corner of the screen and choosing the Restart option, or by pressing the Ctrl, Shift, and Refresh keys at the same time.
  • Adjust your Chromebook's screen position. By gently adjusting the position of your Chromebook's screen, we can see if the issue is caused by a loose connection or misalignment. If the lines change, or disappear, it is likely an issue caused by the connection.
If the lines on the screen are persisting after trying the above steps, try connecting an external display to your device. If the lines are visible on the external display, then this could indicate an issue with either the operating system or your device's settings.
If the lines are not visible, then your Chromebook's display may have been physically damaged.
Issue Caused by the Operating System
ChromeOS might be experiencing issues with the operating system, that might be causing issues with how content appears on your screen. It's recommended that you check to see if there is an update available for your Chromebook. You can check what version of Chrome OS your device is running by following these steps.
  1. Click on the clock in the bottom-right corner of the screen.
  2. Select the gear icon to open the Settings menu.
  3. Scroll down and click on About Chrome OS.
  4. Click on Check for updates and let the system update if any updates are available.
  5. Restart your Chromebook and check if the lines on the screen persist.
Issue Caused by the Display Settings
If your display settings have been adjusted recently, then this could cause an issue with lines appearing on your screen. Adjust each of the settings below, and see if the lines on your screen change.
  • Brightness: Adjust the brightness of the display to see if it affects the appearance of the lines. Sometimes, extreme brightness settings might reveal or hide certain visual artifacts.
  • Screen Resolution: Experiment with different screen resolutions to see if the lines are affected. Lower resolutions might result in a less detailed display, but it can help isolate potential issues.
  • Color Settings: Some display issues might be related to color calibration or settings. You can try adjusting color temperature, contrast, and saturation to see if it makes any difference.
  • Display Orientation: On some Chromebooks, you can change the display orientation (landscape, portrait) in the settings. Changing the orientation might help identify if the lines are specific to a particular orientation.
  • Night Light or Blue Light Filter: If your Chromebook has a night light or blue light filter feature, try enabling or disabling it to see if it affects the appearance of the lines.
You can also Powerwash your device, or use a ChromeOS Recovery USB Drive, to factory reset your device.
Note: This will wipe any data stored on the Chromebook and will factory reset the device. Be sure to back up any data that you want to keep onto an external storage device, or to Google Drive.
Physical Damage to the Display
If any of the above tricks could not resolve the issue with your Chromebook, then there is a good likelihood that your screen, or other component, might be physically damaged. Try these simple steps to resolve the issue.
  • Inspect your display for any physical damage. This will include any large or small fractures in the display. If the screen is damaged, the best solution is to replace it.
  • Perform a visual inspection of the display cable. If there is no visible damage to the screen, or if replacing the LCD panel has not resolved the issue, then conduct a thorough examination of the display cable and its connections. Check both the end of the display and the point where the display cable connects to the motherboard. Look for any signs of damage, such as burns or indications of liquid damage.
If your Chromebook still has lines on the display, continue to the last section.
Motherboard Damage
If your device is still showing lines on the display, then there is most likely an issue with your device's Motherboard.
  1. Reset your device's BIOS Settings. To reset your motherboard's BIOS settings, you can try uninstalling and then reinstalling the CMOS battery. By doing so, any stored settings or configurations that may have become corrupted will be cleared, and the system will start with default settings. This helps eliminate potential conflicts or misconfigurations that could be causing the issue you're experiencing.
  2. Verify that the RAM modules are installed correctly and functioning properly. If the RAM module is not properly seated, it can result in display issues. Try re-inserting the RAM module, ensuring it is securely in place. Alternatively, you can consider replacing the RAM module with the same type to eliminate any potential RAM-related problems.
  3. Perform a thorough visual inspection of the motherboard for any signs of burns or damaged components. If you observe any visible damage, such as burns or components that appear to be physically damaged, the motherboard likely needs to be replaced.
Chromebook has no Sound
First Steps
Before undertaking elaborate repair steps, try some basic troubleshooting steps before going deeper into the repair process.
  • Check to see if you have any External Audio Connections: If you're trying to use your device's internal speakers, then ensure you have no additional audio connections connected to your device. This includes any headphones, speakers, or USB headsets.
  • Ensure that your audio device is turned on and has power. Some speakers might require more power than what can be given through the built-in headphone jack. This means a power source is needed for the speaker to function normally. If you are using a speaker that needs to be plugged in, then make sure that the speaker is powered on or is connected to power. Alternatively, if you use a Bluetooth speaker that uses a battery, you will want to ensure that your speaker is charged.
  • Check your device's Volume and Mute Settings: Ensure that the program or website you are using is not muted or that the volume is set low. You should also ensure the volume on your Chromebook is turned up and not muted. Look for the volume icon in the system tray, adjust the volume level, and ensure that the mute option is not enabled.
Issues Caused by an External Audio Connection
If you frequently connect your Chromebook to an external speaker, there may be an issue with how your Chromebook connects to your speaker or a problem with the speaker itself. You can follow these tips to test the connection.
  • Check your device's sound output. You can check if your device uses the correct audio output by clicking the taskbar where the time is displayed and clicking the left-pointing arrow next to your audio slider to display the Audio settings menu. Once there, you will see a section of Audio Outputs that are usable for your device. Once there, ensure that the correct audio output is selected.
  • Repair your Bluetooth Speakers or Headphones. If you use a set of Bluetooth headphones or a Bluetooth speaker, you can attempt to repair your Bluetooth headphones. You can check your device's Bluetooth settings by clicking the taskbar and toggling the Bluetooth Icon. Click the word 'Bluetooth' underneath the Bluetooth icon to get a list of Bluetooth devices ready to be paired, and select your Bluetooth device.
Audio issues with the Application or Website
Some websites and programs have dedicated audio controls, allowing users to change the outputted audio from the application.
  • Make sure the volume of the program is turned up. Look at settings that would allow you to adjust the application's audio.
  • Check if the tab has been muted. Chrome allows the user to mute the sound coming from a tabbed webpage. If the tab is muted, sound will not play from that tab. You can unmute a tab by clicking the speaker icon that is displayed within the tab.
  • Clear your browser's cached data. Open the Chrome browser and click the three-dot menu icon in the top-right corner, then go to Settings > Privacy and Security> Clear browsing data.
The issue caused by the Operating System
ChromeOS might be experiencing issues with the operating system that might be causing problems with your audio.
  • Ensure that your Chromebook's operating system is up to date. Go to Settings > About Chrome OS > Check for Updates. Install any available updates.
  • Recover your Operating System. If updating your device does not restore sound to your Chromebook, you can try to use a Recovery USB. You can create a recovery USB using the instructions here. This will factory reset your device and wipe any data on the device's internal storage, so be sure to move any data on the device to either an external USB storage device or to Google Drive.
Issues with the Internal Speakers/Motherboard
If you're still experiencing issues with your audio, there might be a problem with the internal speakers or their connection.
  • Remove any debris or liquid damage that would restrict the movement of the speakers. Laptop speakers produce sound by causing a thin diaphragm to vibrate and disrupt the air around it to form the intended sound. If this diaphragm's movement is restricted, then it won't produce sound.
  • Ensure that the internal speaker is correctly connected to the logic board. Follow the connection of your speaker to where it relates to the logic board. If this connection is not seated correctly, then no sound will play from the speakers.
  • Look for any visible damage that would prevent the speaker from working. If the speaker has become damaged, then there is a good chance that you will need to replace the speaker.
  • Perform a thorough visual inspection of the motherboard for any signs of burns or damaged components. If you observe any visible damage, such as burns or parts that appear to be physically damaged, the motherboard likely needs to be replaced.
Chromebook Overheating
Blocked Exhaust Vents
If the laptop's cooling vents are blocked, the laptop will get too hot. Ensure that these vents are not blocked by anything. If the computer stays hotter than usual, read on.
Dust and Debris Have Accumulated Internally
If the internal cooling fan is clogged with dust, it will not be able to cool the inside of the computer. Use compressed air to clean it out.
  1. Power off your Chromebook
  2. Open your device.
  3. Using compressed air and a soft brush, gently clean the fan vents and the surrounding areas.
  4. Ensure that the cooling fan and heatsink are free from any obstructions.
  5. Once everything is clean, reassemble your device and check if the fan noise has reduced.
If the device still runs hot, move on to the next option.
ChromeOS is Out of Date
Outdated software can cause your cooling fan to run unnecessarily fast. You can ensure that ChromeOS is up to date by doing the following.
  1. Click on the time in the bottom-right corner of your screen and select the gear icon to access Settings.
  2. Scroll down and click the option About Chrome OS.
  3. Click on Check for Updates and install any available updates.
If no ChromeOS update is available for your device, or the issue has not been resolved after you have finished updating, continue to the next section.
Significant Resource Usage
Suppose you are running multiple applications or have numerous browser tabs open simultaneously. In that case, this can strain system resources and cause the fan to spin faster due to heat generated by the system. Typically, when this is the case, you might notice that your Chromebook is slower than usual.
You can also see which applications use a significant amount of power using ChromeOS's Task Manager by tapping the Search button and Esc on your Chromebook's keyboard.
Issue Caused by Hardware or Software
If you notice that your fan is constantly running loudly, the issue might be caused by an underlying hardware issue. Often, resetting the hardware resolves this issue.
  1. Power off your Chromebook.
  2. Disconnect the charger.
  3. Locate the small pinhole on the bottom or side of your device.
  4. Insert a paperclip or similar object into the pinhole and press the reset button for 10 seconds.
  5. Release the button and power on your Chromebook to see if the fan noise has decreased.
If your device does not have this pinhole, then follow these steps.
  1. Power off your Chromebook completely.
  2. Disconnect the charger from your Chromebook.
  3. Press the Refresh key (usually above the four keys) and the Power button simultaneously.
  4. Continue holding both buttons for about 10 seconds.
  5. Release the buttons.
  6. Power on your Chromebook and check if the fan noise has improved.
If the issue continues, it may be an issue with the Chromebook's Operating System. If so, you may need to restore ChromeOS using a Recovery USB. Thankfully, the process is straightforward, and the instructions are here.
This will restore your device to the factory default, so ensure that all the files you want to save are either backed up to Google Drive or to an external storage device.
Chromebook won't turn on
Are you noticing no signs of life from your Samsung Series 5 Chromebook? Are you unable to charge your device? Have a look at the tips below.
First Steps
It can be easy to become frustrated and forget some basic troubleshooting steps. Before delving into any of the more elaborate repair processes, be sure to check the following.
  • Ensure that the charging cable of your Chromebook is correctly seated in the charging port. If you have depleted the battery and are attempting to charge the device, ensure the charger is securely connected to the charging port and plugged into a functioning power source. A complete circuit must be established between the charger, the Chromebook, and the power source to enable proper charging.
  • Ensure that the power source your charger is plugged into is powered on. It is possible to overlook a non-functioning power source. Try plugging your Chromebook into a different power source to avoid any issues.
  • Verify your charging cable is not damaged. Inspect the charging cable for any visible signs of damage or frayed wires. If you detect any damage, consider using a different line or replacing the current one.
  • Verify your device's charging indicator light is functioning correctly. When connected to power, see if the charging indicator LED illuminates or changes color, indicating the charging status of your Chromebook.
  • Attempt a hard reset of your Chromebook. Press and hold the power button for at least 10 seconds to discharge any built-up power and possibly resolve software glitches. Then, try powering on your Chromebook again.
  • Ensure your charging port is clean. Dust or debris can sometimes accumulate in the charging port, preventing the proper connection. Use a soft brush or compressed air to clean the charging port gently.
If these steps cannot resolve the issue, continue to the troubleshooting steps below to diagnose your issue.
Drained/Dead Battery
The first thing to check for when your Chromebook won't turn on is a dead battery. Plug the unit in, let it charge for at least 30 min to an hour, and try turning it on again.
  1. Check Battery Level: Connect your Chromebook to the charger and wait at least 15 minutes. Then, see if the charging indicator light shows the device is charging. If not, the battery might be completely drained or faulty.
  2. Try a Different Charger: Use a different charger that's known to work with your Chromebook model. The original might be defective if the device starts charging with the new charger.
  3. Remove External Peripherals: Disconnect external devices such as USB drives, headphones, or monitors. Sometimes, a faulty peripheral can prevent the Chromebook from powering on.
  4. Reset the Battery: Your Samsung Series 5 Chromebook should have a small pinhole reset button on the bottom or side of the device near the back feet. Insert a paperclip or a similar tool into the pinhole and press gently to reset the battery. Afterward, try powering on the Chromebook.
Faulty Screen
Often, when a Chromebook appears to be off, but has an active power in it could be that the device is on, and the screen itself isn't displaying any content.
First, try powering your Chromebook off by holding the power button down for six seconds, then turning it back on again. If you still cannot display any content on the screen, let the battery run out until it powers off, then charge the battery back up and power it on again.
If this does not work, reset your Chromebook with the following steps:
  • Power off your Chromebook.
  • Insert a paperclip into the reset hole on the back feet of the laptop's underside.
  • While pressing the paperclip in, press the power button.
Overheated computer
If no lights turn on when the power button is pressed and the computer is very hot on the bottom, your issue might be caused by overheating. You will have to wait a few minutes until it has cooled down. Unplug the laptop from its power cable and let it sit with the vents unobstructed.
Try turning the computer on again after at least 10-15 minutes. If it boots normally, the computer is too hot. Try using the laptop on a hard surface to help prevent this in the future.
Your Chromebook could have encountered an issue during a ChromeOS update, causing it to appear off or display a black screen. This is due to a lack of proper instructions from the software to boot up. To resolve this, you can restore ChromeOS by following this guide or the instructions below.
Note: Performing a ChromeOS recovery will erase all the data stored directly on the Chromebook.
  1. Go to the Chromebook Recovery Utility website using a separate device.
  2. Install the Chromebook Recovery Utility.
  3. Prepare a USB recovery drive: Connect a USB flash drive (8GB minimum) to the computer and launch the Chromebook Recovery Utility. Select your Chromebook model from the list and click Continue. The utility will download the necessary recovery image to the flash drive.
  4. Recover ChromeOS on your Chromebook: Insert the USB drive into the affected Chromebook. Please turn it off, hold the Esc and Refresh (F3) keys, and press power to start the recovery.
  5. Follow the on-screen instructions to complete the recovery process. Your Chromebook will be restored to its original factory settings with a fresh installation of ChromeOS.
If the issue persists even after restoring ChromeOS, it may indicate a hardware problem. In such cases, continue to the next section.
Faulty Storage Drive
If lights turn on when the power button is pressed, but ChromeOS does not load, your computer's storage drive may be broken. The screen will display a message saying, "No operating system found." You must replace the hard drive; the instructions are on our site.
Faulty Motherboard
If no lights turn on when the power button is pressed, even when the battery is charged, your Motherboard is likely at fault. If it is still covered by warranty, you can send the laptop to the manufacturer to replace it or try repairing it yourself.
USB Ports Not Working
First Steps
Before undertaking significant repairs on your device, you must go through basic troubleshooting steps. These steps can often resolve issues without the need for extensive repairs. Please ensure you check the following.
  • Ensure that your USB device is on and not faulty. Sometimes, the issue could be with the USB device, not the Chromebook. Be sure to test the USB devices on another device to confirm if they work correctly. You should also try connecting different USB devices to your Chromebook to see if the issue persists. Some large storage devices might also require a separate power source, so ensure your USB device is powered on or connected to power. If you find the issue with your USB device, try seeing if the device is in our Computer Hardware Section.
  • Test the USB device with a different USB port. You can determine if the port is faulty by testing your USB device with a different USB port. If the USB device does not connect with your device, then the likely culprit is the USB device itself. Otherwise, the USB port on your Chromebook is the culprit.
  • Make sure that both ends of the USB device are seated correctly. A proper connection is needed to plug your device into your Chromebook's USB port. Try reseating the USB end of your device into your Chromebook's USB port, and ensure the connection does not feel loose. If your USB device plugs into the USB device, ensure that this end is connected correctly.
  • Restart your Chromebook. Restarting your Chromebook will clear out any problematic temporary files and reset any software components that might not be responsive. To restart your Chromebook, click on the system tray, select the power icon, and choose Restart. You can restart your Chromebook by pressing the Esc + Refresh (F3) keys simultaneously and then pressing the Power button.
If these quick tips cannot resolve the issue with your USB ports, try the more in-depth troubleshooting tips below.
Your USB is Not Compatible
Assuming the USB device you are attempting to use is a storage device, it is essential to remember that only some storage formats are compatible with Chrome OS. If your USB runs in an unsupported format, your storage drive won't work. The following supported file formats are listed below.
  • FAT (FAT16, FAT32, exFAT)
  • HFS+ (read-only on journaled HFS+)
  • ISO9660 (read-only)
  • MTP
  • NTFS (Supported for ChromeOS after 2021)
  • UDF (read-only)
If your storage device is not one of the listed file formats, you can format your drive using the following steps.
  1. Open Explorer.
  2. Right-click on the USB drive and select Format from the context menu.
  3. In the File System option, choose a supported format.
  4. Click on the Format button.
If converting your storage device could not fix the problem, or if this section does not apply to you, try the next section.
Dirty USB Ports or Damage
If you cannot use the USB ports on your Chromebook, there may be an issue with the physical hardware.
  • Ensure that your USB Ports are clean and free of debris. USB devices rely on several metal pins that need proper contact with the pins inside the USB connector. If dust or debris has gotten into the USB port, then this could cause the connection between the pins not to be complete. You can use a dust blower and 90% rubbing alcohol to clean out the port.
  • Perform a thorough visual inspection of the USB Ports on your Chromebook. If your USB port has become damaged, then this can cause issues with how your USB device connects to your Chromebook. Perform a visual inspection of your Chromebook's USB ports, looking for any breaks in the plastic support tang or bent or broken contacts. If either of these is broken, you must replace the port or the board the port is connected to.
Issue Caused by Operating System
If the above tips cannot resolve the issue, there might be an underlying issue with your device's operating system. Here are a few issues that might be causing your issue and how you can resolve them.
Outdated Operating System
You can check if your operating system is outdated by going to Settings > About Chrome OS > Check for Updates. Install any available updates. Updates often include bug fixes and often contain performance improvements for your operating system.
Other Underlying Issues
If updating your device could not resolve the issue, you might need to Powerwash your device. You can do this in a few ways, but the easiest way of Powerwashing your Chromebook is with the instructions below.
Note: This will factory reset your device, so be sure to back up all your data to either Google Drive or an external storage device.
Additional information on Powerwashing your device can be found here.
  1. Sign out of your Chromebook by clicking on your profile picture in the bottom right corner of the screen and selecting Sign Out. (You'll need to be at the login screen.)
  2. Press the following key combination on the login screen: Ctrl + Shift + Alt + R Twice.
  3. A dialog box will appear, asking you to confirm that you want to Powerwash your Chromebook. Click on the Powerwash button to continue.
  4. Follow the on-screen instructions to complete the Powerwash process. Your Chromebook will be factory reset.
  5. After the Powerwash is complete, your Chromebook will start as if it were a new device. Follow the on-screen instructions to set up your Chromebook, including connecting to a WiFi network and signing in with your Google Account. Once this is done, check if you can use your USB devices.
Alternatively, you can completely restore ChromeOS using Google's ChromeOS Recovery Tool. This tool can address any potential software issues causing your device to have trouble seeing your USB devices. The instructions for creating a ChromeOS recovery disk are below, but an in-depth guide can be found here. An empty USB drive with at least 8 GB of storage is required.
  1. Install the Chromebook Recovery Utility Extension: Open Google Chrome and install the Chromebook Recovery Utility Extension from the Chrome Web Store. Click on the extension and follow the on-screen instructions.
  2. Prepare Chromebook for Recovery: Turn off your Chromebook and ensure it's connected to a power source. Press the Esc + Refresh (F3) keys simultaneously, then press the Power button. Release the Power button when the Chromebook starts, but continue holding Esc+ Refresh until you see a screen prompting you to insert the recovery disk.
  3. Recover ChromeOS: Insert the previously created recovery disk into your Chromebook and follow the on-screen instructions to initiate the ChromeOS recovery process. This will reinstall the operating system and can resolve software-related problems that may be causing the black screen issue.
  4. Follow System Setup: After completing ChromeOS recovery, follow the on-screen instructions to set up your Chromebook as you would during the initial setup. Check if you can use your USB device.
Internal Hardware
If the above sections have been unable to resolve the issue, then there could be the possibility that there may be an issue with your device's internal components.
  • Perform a thorough visual inspection of the motherboard for any signs of burns or damaged components. If you observe any visible damage, such as burns or components that appear to be physically damaged, the motherboard likely needs to be replaced.
No Internet Connection
Before attempting any significant repair processes, be sure first to check the following.
  1. Check WiFi Signal: Verify your Chromebook is within a functioning WiFi network range. Ensure you are in the router's range and no physical obstructions are blocking the signal.
  2. Ensure WiFi is Enabled on your device: Press the WiFi key (usually represented by an antenna icon) on your Chromebook's keyboard to ensure WiFi is enabled. You can also check by clicking on the system tray in the bottom-right corner of the screen and ensuring the WiFi icon is turned on.
  3. Check for Airplane Mode: Make sure your Chromebook is not in Airplane Mode, which disables all wireless connections. Disable Airplane Mode by clicking on the system tray and turning off the Airplane Mode icon.
  4. Double-check WiFi Password: If you connect to a password-protected WiFi network, ensure you enter the correct password. Pay attention to uppercase and lowercase letters, special characters, and spaces.
  5. Test with Another Device: Verify if other devices can connect to the same WiFi network. If other devices are also experiencing connectivity issues, the problem may lie with the WiFi network itself.
  6. Restart your Chromebook and the Router: A simple restart can sometimes resolve temporary connectivity issues with both devices.
An issue with Initial Automated WiFi Configuration
ChromeOS sometimes has issues connecting to a network if your device is automatically assigned an IP address. These issues can be resolved by forgetting the WiFi network and reconnecting to it.
  1. Click on the WiFi Icon: Click on the WiFi icon in the system tray to open the network list.
  2. Find the Affected WiFi Network: Locate the WiFi network that your Chromebook is having trouble connecting to. Click on the network name to expand the connection options.
  3. Click on "Forget": Once the connection options are expanded, click the "Forget" button next to the network name. This will remove the network from your saved list.
  4. Reconnect to the Network: After forgetting the network, click the WiFi icon again and select the network from the list. Enter the correct password and attempt to connect.
  5. Check Connection: Check if your Chromebook can access the Internet through the WiFi network.
Broken or Mis-Configured WiFi router
Your router could be faulty if your laptop does not connect to the Internet. Try connecting a different device to the same wireless network. If that device has issues connecting, reset the router and check that all cables are plugged in correctly. If, after a reset, devices still can't connect to the router, the router is faulty, or your Internet provider is down.
Issue with Cached Data
If a cached file becomes corrupted, it can cause issues connecting to your network. Clearing the WiFi network data can help resolve issues with saved network settings. Follow these steps:
  1. Open Settings: Click on the system tray and the gear-shaped "Settings" icon to open the Chromebook settings.
  2. Expand "Advanced": Scroll down and click on the "Advanced" section to reveal additional settings.
  3. Click on "Privacy and Security": Under the Advanced section, click "Privacy and Security" to access related settings.
  4. Click on "Clear Browsing Data": In the Privacy and Security section, click "Clear Browsing Data" to open the data clearing options.
  5. Choose WiFi NetworksCheck the "Cookies and other site data" option in the Clear Browsing Data settings settings. Uncheck any other options that you don't want to clear.
  6. Click on "Clear Data": Once the desired options are selected, click the "Clear Data" button to clear the WiFi network data.
  7. Reconnect to the Network: After clearing the data, attempt to reconnect to the WiFi network and check if the issue is resolved.
If the previous steps didn't resolve the WiFi connectivity issue, you can attempt to Powerwash your Chromebook. You can do this in a few ways, but the easiest way of Powerwashing your Chromebook is with the instructions below. This will factory reset your device, so back up all your data to either Google Drive or an external storage device.
  1. Sign out of your Chromebook by clicking on your profile picture in the bottom right corner of the screen and selecting "Sign out." (You'll need to be at the login screen)
  3. A dialog box will appear, asking you to confirm that you want to Powerwash your Chromebook. Click on the "Powerwash" button to continue.
Alternatively, you can completely restore ChromeOS using Google's ChromeOS Recovery Tool. This tool can address any potential software issues causing your device to have trouble seeing your network. The instructions for creating a ChromeOS recovery disk are below, but an in-depth guide can be found here. An empty USB drive with at least 8 GB of storage is required.
  4. Follow System Setup: After completing ChromeOS recovery, follow the on-screen instructions to set up your Chromebook as you would during the initial setup. Check if the black screen issue is resolved.
If Powerwashing or restoring your device could not resolve your issue, the problem might be with your device's WWAN Board.
Issue Caused by the WWAN Board
Sometimes, the device's internal WWAN might be experiencing an issue. Before opening the device up, be sure to check the following.
  • Restart WWAN Board: Press and hold the refresh key (usually located where the F3 key would be) and tap the power key. Release the keys once your Chromebook restarts. This will refresh the network card and may resolve any temporary issues.
  • Update network drivers: Ensure your Chromebook's operating system is current. Go to "Settings"> "About Chrome OS"> "Check for Updates." Install any available updates, including updates for network drivers.
  • Test with an external Wireless Adapter: Using a wireless adapter, you can ensure your device can reach the network and determine if your WWAN Board needs replacing. However, if you cannot reach the WiFi with an external adapter, there is likely an issue with your device's Motherboard.
  • Replace the WWAN Board: If all else fails, you can replace your device's network card and see if your device can detect your wireless network. iFixit does feature a guide for replacing your Chromebook's WWAN Board.
If these steps have failed, there is most likely an issue with your device's Motherboard.
Suppose your device is still not seeing your wireless network after following the troubleshooting steps mentioned earlier. In that case, there is a high likelihood of a problem with the Motherboard or the surrounding components.
  1. Reset your device's BIOS Settings. To reset your Motherboard's BIOS settings, you can try uninstalling and then reinstalling the CMOS battery found attached to your Chromebook's Motherboard. By doing so, any stored settings or configurations that may have become corrupted will be cleared, and the system will start with default settings. This helps eliminate potential conflicts or misconfigurations that could be causing the issue you're experiencing.
  2. Check for Defects that would cause Network Connectivity issues: Ensure that your Motherboard is not bending or experiencing any issues that would not allow your WWAN Board to not sit correctly in its port.
  3. Perform a thorough visual inspection of the Motherboard for any signs of burns or damaged components. If you observe any visible damage, such as burns or components that appear to be physically damaged, the Motherboard likely needs to be replaced.
Chromebook Running Slowly
First Steps
  • Close Unnecessary Tabs and Applications: Multiple open tabs and applications can consume system resources and impact performance. Keep only the essential ones open. You can see which applications use many resources using ChromeOS's Task Manager by tapping the Search button and Esc on your keyboard.
  • Restart Your Chromebook: Restarting your Chromebook will clear out any problematic temporary files and reset any software components that might not be responsive. To restart your Chromebook, click on the system tray, select the power icon, and choose Restart. You can restart your Chromebook by pressing the Esc + Refresh (F3) keys simultaneously and then pressing the Power button.
  • Check Your Internet Connection: If web-based applications are particularly sluggish, there might be a good chance of an issue with your network connection.
One of the reasons that your Chromebook could be running slowly could be due to several different issues caused by the operating system.
  • The potential issue caused by Cached Data: If a cached file becomes corrupted or enough of them are stored, it can cause your system to become slow. You can clear your browsing data by following the below steps.
    • Open Settings: Click on the system tray and the gear-shaped "Settings" icon to open the Chromebook settings.
    • Expand "Advanced": Scroll down and click on the "Advanced" section to reveal additional settings.
    • Click on "Privacy and Security": Under the Advanced section, click "Privacy and Security" to access related settings.
    • Click on "Clear Browsing Data": In the Privacy and Security section, click "Clear Browsing Data" to open the data clearing options.
  • Outdated Operating System: You can check if your operating system is outdated by going to Settings > About Chrome OS > Check for Updates. Install any available updates. Updates often include bug fixes and often contain performance improvements for your operating system.
Issue Caused by Unnecessary Extensions
Disabling or removing unnecessary extensions can significantly improve the speed and performance of your Chromebook. Each extension you have installed on your Chromebook consumes system resources such as CPU, memory, and disk space. You can check and turn off your extensions by doing the following.
  1. Click on the three-dot menu icon in the top-right corner of the Chrome browser.
  2. Go to More Tools > Extensions.
  3. Disable or remove any unnecessary or unused extensions that might consume system resources and slow down your Chromebook.
Some extensions run continuously in the background and collectively contribute to increased resource usage, which can slow down your Chromebook. Disabling or removing unnecessary extensions can reduce the overall resources consumed, allowing your device to allocate its resources more efficiently.
Device is overheating
If your device is too hot, the operating system will slow down to protect the processor. Feel the bottom of the device to see if it is hot. Shut down the computer and let it cool down. If your laptop still overheats, see the Computer Overheating section above.
Potential Issue Caused by Malware
ChromeOS is designed to be secure and virtually immune to viruses. However, they are still very susceptible to malware, which can cause issues with processing speeds. This is why it's always a good idea to ensure your device is free from malware or unwanted software by doing the following.
  1. Open the Chrome browser.
  2. Click on the three-dot menu icon in the top-right corner.
  3. Go to Settings and scroll down to the Privacy and Security section.
  4. Click on Security.
  5. Under the Security section, click on Check for malicious software.
You can also factory reset your device by performing a Powerwash. Ideally, you would want to save your data onto an external USB storage device or Google Drive before doing this, as this will reset the computer to the factory default state.
  2. Click on the account picture or initials in the bottom-right corner.
  3. Click on Settings.
  4. Scroll down and click on Advanced.
  5. Under the Reset settings section, click on Powerwash.
  6. Follow the on-screen instructions to complete the powerwash process.
Performing a powerwash can help resolve more complex issues, including persistent performance problems, software conflicts, or system errors.
Note: Powerwashing will erase all your data, so it's crucial to back up any important files before proceeding.
Chromebook Screen Upside Down
Screen Accidentally Rotated
In some cases, this issue occurs when a specific set of keys are accidentally pressed — typically in the case of children who mash the keyboard, or when a cat or other small animal lies on the keyboard. This feature is a normal feature of ChromeOS and is thankfully easy to resolve by following the below steps.
  1. Press and hold the CTRL + Shift keys and press the Refresh key (circle with arrow) to rotate the screen 90 degrees clockwise.
  2. Repeat Step One until your screen is properly orientated.
You can also adjust your screen rotation in your Chromebook's settings by using the following steps.
  3. Scroll down and click on Advanced to expand the advanced settings.
  4. Under the Device section, click on Displays to access the display settings.
  5. Look for the Rotation option and make sure it is set to Standard or 0 degrees.
  6. If it is set to a different rotation, adjust it to the correct setting.
In addition to adjusting the settings, you can also reset your display to its factory default settings by using the following steps.
  1. In the display settings menu, scroll down to the bottom and click on Reset to Default.
  2. Confirm the action when prompted.
  3. This will reset all display settings, including the screen orientation, to their default values.
If these tips were unable to resolve the issue then try the next section.
If the above tips were unable to resolve the issue, then there might be an underlying issue with your device's operating system. One of the things you can do to fix this issue is to Powerwash your device. There are a few ways you can do this, but the easiest way of Powerwashing your Chromebook is with the instructions below.
  2. On the login screen, press the following key combination: Ctrl + Shift + Alt + R Twice.
  5. After the Powerwash is complete, your Chromebook will start up as if it were a new device. Follow the on-screen instructions to set up your Chromebook, including connecting to a WiFi network and signing in with your Google Account.
Alternatively, you can completely restore ChromeOS using Google's ChromeOS Recovery Tool. This tool can be used to address any potential software issues causing your device to have trouble seeing your network. The instructions for creating a ChromeOS recovery disk are below but an in-depth guide can be found here. An empty USB drive with at least 8 GB of storage is required.
  2. Prepare Chromebook for Recovery: Turn off your Chromebook and ensure it's connected to a power source. Press and hold the Esc + Refresh (F3) keys simultaneously, then press the Power button. Release the Power button when the Chromebook starts, but continue holding Esc+ Refresh until you see a screen prompting you to insert the recovery disk.
  4. Follow System Setup: After ChromeOS recovery is complete, follow the on-screen instructions to set up your Chromebook as you would during the initial setup. Check if the black screen issue is resolved.
Helder Avelino
crwdns2935283:010/22/13crwdne2935283:0
938 crwdns2915208:0crwdne2915208:0
University of Maryland, Team 1-7, Shastany Fall 2013 crwdns2935289:0University of Maryland, Team 1-7, Shastany Fall 2013crwdne2935289:0
UMD-SHASTANY-F13S1G7
crwdns2944067:068crwdne2944067:0
Screen is black but I can see the start up page very faintly. It flickered before and corrected it self,museums to have happened when opening or closing the lid. Now permanently dark screen
Isabella Grubb - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Did you find a solution? I have the same problem, and just wondered if it could be fixed??
Sammie Beene - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
i have the same issue and i think its part of the wiring. samsung didnt put any quality into the chromebooks so they fall apart too easily
Duncan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Your brightness it probably low try pressing the key that resembles a sun the bigger key is to make the screen Brighter while the key that resembles a smaller sun makes your screen dimmer.
Benyah Andressohn - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Same issue, it is really frustrating. I thought the screen burn out but it’s probably the wiring
Taylor Foster [Student HBHS] - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 70
crwdns2959996:0crwdne2959996:0 300,112
