crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If the buttons on your Razer Wolverine V3 Pro controller do not respond when pressed, this troubleshooting page may have a solution.
Debris Obstructing Button Contacts
If the buttons on the controller do not respond when pressed, a possible cause may be debris build-up that occurs over time in the void areas of the controller.
  1. Power off the controller and disconnect it.
  2. Use compressed air to blow around the edges of the affected button.
  3. Use a soft brush from the iFixit toolkit to loosen debris.
  4. If necessary, lightly clean the area with isopropyl alcohol and a cotton swab to remove buildup.
  5. Allow the controller to fully dry up before powering on.
Outdated Controller Firmware
The controller requires constant updating for optimal performance.
  1. Connect the controller to a PC using a USB cord.
  2. Download and launch the application ‘Firmware Updater’.
  3. Follow the instructions on the screen to install the latest firmware.
  4. Do not disconnect the controller from the PC during the updating process.
  5. After updating, restart the controller and test the buttons again.
Loose Button Ribbon Cable
A loose or damaged internal ribbon cable may prevent button inputs from reaching the main board.
  • This requires opening the controller.
  • Connect the internal ribbon cable from the button board to the motherboard.
  • Follow this guide: Controller Disassembly Guide
Worn or Damaged Button Mechanism
If cleaning and updating the firmware do not resolve the issue, the button mechanism may be worn or damaged. Replacing the button may restore its functionality.
  • Follow the replacement guide for instructions on how to remove and install the new component safely.
  • Follow this guide: Button Replacement Guide
crwdns2935291:0crwdne2935291:0
Hidaya Nader Asad
crwdns2935283:002/15/26crwdne2935283:0
251 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 3-2, Sneed Spring 2026 crwdns2935289:0University of Memphis, Team 3-2, Sneed Spring 2026crwdne2935289:0
UM-SNEED-S26S3G2
crwdns2936753:07crwdne2936753:0 41
crwdns2936753:030crwdne2936753:0 181
crwdns2959996:0crwdne2959996:0 810
