crwdns2944686:0crwdne2944686:0
If your device is swollen, bulging, overheating, or smoking, discontinue use immediately and replace the battery. It may not be to blame, but it should be replaced regardless. Be sure to dispose of your swollen battery properly.
The Basics
Before undertaking substantial repairs on your device, consider these basic troubleshooting steps:
  • Check Power Source: Check the power source. Try connecting another device, using a different cable, swapping the plug to a different charging port (if available), and plugging it into a different outlet to ensure it’s working correctly.
  • Perform a Hard Reset: Perform a hard reset by turning off your laptop and unplugging it from its power source. If your laptop has a removable external battery, remove it. Hold the power button for 15-20 seconds. Reinsert the battery, plug in your power adapter, and turn on your device.
  • Test with an External Monitor: Connect your laptop to an external monitor. If your device displays on the external monitor but not the built-in screen, check out the Razer Laptop Black Screen page.
Battery Fault
Solution: Inspect and Replace the Battery
Batteries are nefarious. They fail often due to their "consumable" nature, but not always in predictable ways. Although they typically die slowly and with diminishing power on time, a bunk battery could cause a no-power problem. In case of a failed battery, replace it using one of our replacement guides.
  • Disconnect the battery and try to power it on. Most Razer laptops will boot without it. If it powers up, the battery is likely your issue.
  • Check for visual signs of battery age, swelling, or leak. Swollen batteries may manifest as difficulty in using the trackpad or the keyboard. As the battery expands, it exerts upward pressure on the underside of these components.
  • Reset your device's battery. This usually involves pressing and holding a combination of keys; refer to your laptop's user manual for instructions, as the procedure will often vary depending on the specific device.
  • Replace your battery. Battery degradation is inevitable. You can check your battery's health. However, this will vary depending on your operating system. Some Razer laptops make it easier than others, and iFixit makes it easy to source a Razer Laptop Batteries.
Faulty RAM
Faulty or improperly seated RAM can prevent the system from booting correctly. If you see something on the screen but your computer won't boot, this is a likely cause.
Charging Port Damage
Solution: Inspect the Charging Port for Damage and Replace or Repair
Depending on the specific model of the Razer laptop, you might be using a USB-C charging cable or a barrel-style charging cable.
  • Perform a thorough visual inspection of the charge port. Use a flashlight for USB C-port interiors. It's an easy entry point for liquid, and corrosion can live there undetected.
  • Wiggle the cable gently to see if you can get a better connection. If the port is loose, the internal pin may not make enough contact to charge the battery.
  • Check for signs of corrosion or burn. If anything looks questionable, open the machine and pull out the affiliated part for a better look.
    • Spills commonly damage USB-C ports. Even if the liquid doesn't penetrate the machine's interior, corrosion in the port can spell trouble.
    • Barrel connectors are likelier to suffer from bent pints or broken plastic parts. If your port feels loose, it's likely this is to blame.
  • If you find damage that can't be fixed or corrosion that can't be removed, find a replacement. In many cases, it is a modular component. If it's soldered onto the motherboard—like a USB-C port—you'll need some soldering chops to proceed (or replace the affected board).
Motherboard Damage
Solution: Replace the Motherboard
What if your Razer laptop still does not power up, even after following all the troubleshooting steps above? Signs point toward a problem with the motherboard or surrounding components.
  1. Ensure that your device's CPU is adequately cooled: If you recently reinstalled your heat sinks, double-check that they are correctly attached to your CPU and that the CPU has the appropriate amount of thermal paste applied. Proper cooling is essential to prevent overheating and ensure optimal performance. Also, ensure your device's fans are plugged in, working, and spinning freely in their housing.
  2. Remove any accumulated dust or debris from your device's internal components. Maintaining proper airflow within your device is crucial. Dust or debris can hinder the cooling process, potentially causing issues with the operating system. Regularly cleaning your device's internals helps prevent excessive heat generation and ensures optimal performance.
  3. Reset your device's BIOS Settings. To reset your motherboard's BIOS settings, you can try uninstalling and then reinstalling the CMOS battery. By doing so, any stored settings or configurations that may have become corrupted will be cleared, and the system will start with default settings. This helps eliminate potential conflicts or misconfigurations that could be causing the issue you're experiencing.
  4. Perform a thorough visual inspection of the circuit boards for any signs of burns or damaged components: If you observe any visible damage, such as burns or parts that appear to be physically damaged, the board likely needs to be replaced, especially if it's the board carrying the display cable connector.
Jacob Mehnert
crwdns2935283:010/18/21crwdne2935283:0
49.876 crwdns2915208:0crwdne2915208:0
crwdns2935297:052crwdne2935297:0
iFanatics crwdns2935289:0iFanaticscrwdne2935289:0
Community
crwdns2931471:069crwdne2931471:0
crwdns2935297:01.151crwdne2935297:0
crwdns2936753:030crwdne2936753:0 99
crwdns2942667:0crwdne2942667:0 1,471
