crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
The Drone Is Unresponsive To Remote Control
The drone will not respond to commands from the remote control.
Perform The Proper Pre-Flight Checklist
  1. Push the ON/OFF power switch toward ON.
  2. Open the battery cover on the Dronium Two and insert the battery into the power port.
  3. Close the battery cover and turn on the quad-copter.
  4. Push the throttle lever to the highest position, and then pull it back to the lowest position. There will be one beep from the transmitter. This shows that the quad-copter has synced with the remote.
The Device Is Not Synced With The Remote Control
Turn on the controller; if, after 30 seconds, it has not recognized the helicopter, turn off controller to retry synchronization.
You See A Blinking LED
If the quad-copter's LED blinks slowly, it means it has not recognized the controller; please restart pre-flight procedure.
Restart The Pre-Flight Checklist, But With The First Two Steps Reversed
If the Dronium Two and the remote do not sync after following the pre-flight checklist, reverse the first two steps of the process as follows:
  1. Turn the remote off and unplug the cable from the Dronium Two.
  2. Then, turn on the remote first and then plug the cable back into the Dronium Two to turn it on.
Unsteady Flight
Your Dronium Two is experiencing unsteady flight.
Recalibrate The Dronium Two
If the Dronium Two is unsteady in flight, it may not have been able to calibrate horizontally; Power down both vehicle and remote control, and then restart pre-flight procedure. Ensure that the Dronium Two is on a flat and level surface prior to beginning pre-flight procedure.
The Trim Settings Are Incorrect
Reset the trim buttons on the controller and re-trim flight controls.
Your Blade Guard Is Damaged
Click here to see our blade guard replacement guide
Your Rotor Blades Are Damaged
Click here to see our rotor replacement guide
The Response to Remote Control Inputs is Intermittent or Erratic
The drone is behaving erratically.
The Batteries To The Remote Control May Need Replaced
How to replace batteries in remote control.
  1. Unscrew and remove battery cover from controller, using the included screwdriver.
  2. Insert Four (4) x ‘AA’ batteries according to indicated polarities.
  3. Replace and screw back in battery cover.
You're Experiencing Limited Battery Time After Charging
Your battery life is shorter than normal
Do Not Leave Battery Charging After It Is Full
If battery is left in charging state for an extended period of time after being fully charged, the battery may automatically discharge.
Do Not Charge The Battery Immediately After Flight
As battery temperature is high immediately after flight, charge it after it cools down for
better performance.
Follow The Proper Storage Procedures For The Battery
  • Do not use or leave battery near a heat source such as fire or space heater; exposure to heat may result in reduced performance or in some cases dangerous conditions.
  • Charge battery to approximately 55% capacity prior to long-term storage. If battery sees no use for extended periods of time, it is recommended that battery voltage is kept above 3V. Check monthly and recharge as needed.
  • When charging, place product on a dry, well-ventilated surface and keep away from heat sources.
The Battery Is Old Or Worn Out And Needs Replacing
Click here to see our battery replacement guide
After Trying All Of The Above, The Drone is Still Behaving Strangely
I have done everything else, and am still experiencing issues.
How To Perform Factory Reset Of Your Dronium Two
When all else fails, restore factory default settings by the following methods:
  1. Press the power switch to turn on the transmitter.
  2. Press the power switch to turn on the quad-copter.
  3. When the quad-copter indicator flashes slowly, push the throttle lever to the highest position, and then pull it back to the lowest position. The quad-copter indicator will change from slow flashing to steady mode.
  4. Place the quad-copter on a horizontal position, then push both left and right lever on the transmitter to the lowest right corners for 2-3 seconds. The indicator on the quad-copter will change from normal light to quick flashing light. After 2-3 seconds the indicator will change back to the normal light. This means the quad-copter has restarted/reset successfully.
Edwin Brietz
crwdns2935283:001/18/17crwdne2935283:0
581 crwdns2915208:0crwdne2915208:0
Arkansas State University, Team 1-2, Chamberlain Spring 2017 crwdns2935289:0Arkansas State University, Team 1-2, Chamberlain Spring 2017crwdne2935289:0
ARSU-CHAMBERLAIN-S17S1G2
My Dronium Two will turn on and all four blades will turn, but it will get about six inches off the ground and then it will stop turning the blades and reland itself. I have tested the batteries and performed the factory reset. Has anyone else had this problem?
Greg Young - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
How to I reset my controller to factory setting some how I got the controlls switched and I Hate it
Jaiden - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2959996:0crwdne2959996:0 3,159
