crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Controller Won't Turn On
I keep pressing buttons and nothing happens.
It Is Not Connected To The Console
Unplug the cable and make sure you are connecting it in the right slot, then connect it again.
Defective Cable
Your cable may be defective and will not power your controller at all. If this is happening, you have to buy a new cable and replace it.
Controller Won't Respond When Connected To PC
I keep pressing buttons but nothing moves on the screen.
Controller Is Not Receiving Enough Energy
Ensure that you are plugging your controller into a USB port that will provide enough power for the controller to work.
You Don't Have The Right Software Installed
You might not have the correct software that recognizes the controller; check if you even have a software. If not, download one. If this does not work, test your controller on other devices, such as an Xbox console or another computer to check if the controller works.
Sticky Buttons
Some or all the buttons in my controller take too long to pop up
Dirty Buttons
The buttons on your controller might have food residue or just dust. If you want to clean them you will need a cleaning wipe and some alcohol. If that does not work, try opening the controller to clean them more thoroughly or change them.
Controller Will Not Vibrate
When I am playing a game, the controller won’t vibrate.
Vibration Settings Not Enabled
Make sure the vibration option is enabled which is commonly found in the setting of the game you are playing. The vibration option may also be turned off from the console settings.
The Game May Not Support The Vibration Option
Try out a different controller to play the game. If the controller still doesn’t vibrate there is a high chance the game doesn’t support the vibration effect.
Defective Vibration Motor
If you’ve tried all the above and your controller still isn’t vibrating, you most likely have a defective vibration motor. If so, grab a screwdriver because you will need it for the Xbox One Wireless Controller Trigger Rumble Motor Replacement guide. This guide requires soldering.
Part: Xbox One controller trigger vibration motor
Tools required: TR6 Torx Security Screwdriver, TR8 Torx Security Screwdriver, Spudger, soldering station tweezers (recommended)
LED On The Controller Will Not Turn On
My controller is working but the led appears off
Burned LED
If your controller is working but the LED is not on, it might be because it is burned out and you will have to replace it.
Damaged Connections
There might be a problem with the connections between the LED and the power of the controller. This could be either because it has fallen or a beverage has been spilled on it. The best option is to open the controller and check the connections with a voltage tester.
Broken Paddle Mount plastic tabs
The plastic tabs holding my metal paddles broke making the paddle inoperable
After steady use, the plastic tabs where the metal paddles connect to the paddle mount will break off due to wear and tear. While this part is under warranty, PowerA does not have the part in stock due to covid shortages. A gamer designed a custom plate to fix this issue by mounting the plate on top of the paddle mount.
Purchase the custom plate
How to mount the plate Video
Andrea
crwdns2935283:009/26/17crwdne2935283:0
671 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S14-G4, Boczar Fall 2017 crwdns2935289:0USF Tampa, Team S14-G4, Boczar Fall 2017crwdne2935289:0
USFT-BOCZAR-F17S14G4
crwdns2944067:0130crwdne2944067:0
I need a plastic part that goes under the ABYX buttons with the silocone conductors in it, but I can’t find one anywhere.
Conor the Random Human - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
my right trigger auto fires soon as i press the left trigger! meaning its total trash when i play a shooting game or any game that requires either left or right trigger! i just bought it and its already broken!
mikelana - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hey did you ever found the issue or fix for this problem because I’m having the same problem like you and it’s really annoying thanks
joefox111 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
It's happening to me as well. Did you find an soultion?
Mandipkunwar - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thank you I bought 4 of these and 2 out of the 4 shoots while I am aiming down sights
For you non fps players…when I pull the left trigger its malfunctioning and pulling the right trigger as well
Jaquantez - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 106
crwdns2959996:0crwdne2959996:0 126,268
