crwdns2942287:0crwdne2942287:0 ↓In this guide, you will learn how to remove the rumble motors located in the triggers. This task requires you to fully disassemble the triggers on the controller.
Remove the battery pack cover.
Remove batteries.
Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
Use a screwdriver and punch a hole directly in the center of the label.
Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
De-solder the soldered joints while holding the red and black wires down on the top motherboard.
De-solder the black and gray wires that are attached to the top motherboard.
Remove the rumble motors and set them aside.
Unscrew the two 7mm T6 screws located near the rumble motor sockets.
Firmly grip sides of motherboard near the middle.
Lift upwards while slightly wiggling the motherboard forward and backward.
Remove the yellow tape holding the wires in place on the front of the controller.
Unscrew the two 7mm T6 Hex screws located on underside the triggers.
Remove the rumble motors from its socket and pull the wire with it.
crwdns2935229:020crwdne2935229:0
crwdns2947412:010crwdne2947412:0
After a drop onto tile flooring, the side clip of the outer handle snapped and got lodged into the trigger, causing it to only pull to 80% and go no further. Thanks for this breakdown.
solofrom303 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My right trigger won't work on gta 5 and on other games it works
Devean Velasquez - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Very strange, Devean. That sounds more like a software problem than a hardware problem, if I had to guess. If you haven't already, maybe check to make sure that your control setup is correct.
Alternatively, see if you can find any other games that your RT doesn't work for, and see what they have in common with GTA - it might be that the trigger isn't registering as fully depressed, or only ever registering when fully depressed.
Liam Gow - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Trying to replace bumpers assembly and green sync button fell out can not figure how to put it back in.
Anthony Bembenek - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Do you know how to remove the plastic plate where the trigger rumble sits?
Angel Marban - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
