crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Phone Will Drop Calls
The phone will not hold calls.
Faulty Battery
The battery may be corroded, preventing the phone from holding a call. If battery is not corroded, then replace the batteries.
Faulty Power Outlet
Move the charging base to a different power outlet. If the charging base still does not work, then replace the base unit.
Blank Display Screen
The display screen is broken, cracked, or not displaying any information.
Faulty Handset Display Screen
Allow the handset to recharge. If the screen is still not displaying any information, then replace the screen.
Cracked Or Broken Handset Screen
Remove the cracked screen and replace.
Faulty Base Unit Display Screen
Ensure that the power cord is plugged into a wall outlet. If the screen is still not displaying any information, then replace the screen.
Static Sound
There is static sound in the earpiece while on a call.
Broken Earpiece
A earpiece can be damaged if the phone is dropped or mishandled. If the earpiece appears to be broken and does not transmit clearly, replace the earpiece.
Electric Interference
Interference from an outside source will cause static. Check the other phones to see if there is static in those headsets as well. If there is static in the other headsets, replace one headset.
Damaged Cord
Check the cord plugged into the base unit and make sure it is fully connected to both the phone and wall outlet, and check the whole length of the cord for damage. If the cord is securely plugged in and there is still static, or if the cord is damaged, then replace the cord.
Sound Does Not Transmit Through The Phone
No sound is going through the phone.
Mute Button Enabled/Repeater Mode Is On
If no sound is being transmitted, make sure the mute button is not enabled. Turn off repeater mode on the base unit. If sound still won’t transmit, then replace the base unit.
Frequency Interference
If no sound is being transmitted or there is frequency interference, and the phone line is connected to a modem, remove power from the modem. Do so by unplugging the modem from the wall jack and disconnecting the battery (if equipped). Wait 30 seconds, then reinsert the battery (if equipped). Plug the modem into a wall jack, then wait 5 minutes. If this does not fix the issue, replace the base unit.
Activating Speakerphone Causes Phone To Blank Out
When activating the speakerphone feature, the phone drop the call or stop working.
Faulty Batteries
If using the speakerphone causes the phone to drop the call or stop working, then the batteries my need charging. If charging the batteries does not solve the issue, replace the batteries.
Damaged Wire
If activating the speakerphone feature causes the phone to drop the call or stop working, check the speaker wire connections on the motherboard by lightly pulling them with tweezers to see if they are damaged, loosely connected or not connected at all. If so, then replace the wires and/or re-solder them to the motherboard.
Alexa Davis
crwdns2935283:004/08/19crwdne2935283:0
151 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Eastern Washington University, Team S1-G2, Rowley Spring 2019 crwdns2935289:0Eastern Washington University, Team S1-G2, Rowley Spring 2019crwdne2935289:0
EWU-ROWLEY-S19S1G2
My Panasonic cordless phone does not give a dialling tone. Instead I get a beep beep beep repeat sound. The telelphone dept say my tel line is OK and the problem must be with my equipment. What is the solution? (Cape Town South Africa) G.G.Barnett mantec@iafrica.com
Gavin Barnett - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 3,348
