crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Player Won't Turn On
Player won't show signs of turning on
External power line is disconnected or broken
  • Check the power outlet to ensure that it is providing power. If necessary, test with other devices or check other outlets.
  • Check that all cords are properly connected and that there is no damage to the cords. If the cords are damaged then replace as necessary. Check if the power light turns on after replacement.
Disk Unable to Read
Disk is inserted but unable to play
Disk is smudged or broken
  • Try to clean using microfiber, using outward strokes from center to outside edge
  • Test using another disk. If it works then original disk is faulty.
Optical Disk Drive is Broken
Unable to Connect to Wifi
Player is unable to access the internet
WiFi is not properly set up
  • Make sure your wireless network is working with other devices, and is set up according to your internet provider’s specifications
WiFi Module is broken
  • If it is only the wireless reciever that is broken, try running an ethernet cable into the port labelled “LAN” on the back panel of the player.
  • If this does not provide internet access, consider replacing the WiFi Module, see Panasonic DMP-BD89 Wifi Board Replacement for details.
Player Freezes or Locks Up
Player is turned on but is unresponsive
Requires a restart
  • Unplug all cables and USB devices from the player
  • Unplug the power, wait for 30 seconds to a minute, and then reconnect and turn on the player.
Player froze during a firmware update
  • Unplug the power, wait for 30 seconds to a minute, and then reconnect and turn on the player. Make sure the player is once again responsive.
  • Reset the player to factory default settings.
  • Complete the first time setup, and set up a network connection
  • Before attempting to access any network services or apps, perform the firmware update from the menu.
David Sun
crwdns2935283:010/17/17crwdne2935283:0
213 crwdns2915208:0crwdne2915208:0
UC Santa Barbara, Team S2-G9, Weedon Fall 2017 crwdns2935289:0UC Santa Barbara, Team S2-G9, Weedon Fall 2017crwdne2935289:0
UCSB-WEEDON-F17S2G9
crwdns2935297:048crwdne2935297:0
crwdns2944067:04crwdne2944067:0
Unable to watch Youtube app. It was working perfectly until there was a power cut and when it was restored and I wanted to watch a program in Youtube, there was a message saying Internal Communication Error and something regarding “Opera.help” ?
The model of my panasonic blu ray is DMP BD89 which is not included in the list of panasonic devices that google decided to terminate its YouTube service .
I reset my device, wifi is perfectly working, I can enjoy netflix services but not Youtube.
Could you please help me with this issue?
Thank you.
lucia lucia - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Trying to turn on my DVD player and can hear a clicking sound but it's not powering on. Any ideas??
Jaye carah - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
When I power on my player, it makes the transformer "whirr" noise, then motor spin, then it runs. I don't think the "click" sound is normal.
Jri-creator - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
HEY! This is a message to people who have this player. Netflix has decided to discontinue it's support for the player on 10/16/2023. Netflix will no longer stream on the player, even though it may still access the servers and retrieve the data. Some people may have been pre-warned about this already, and may have been prepared for this. I don't know why Netflix decided to do this, possibly due to support for different things not available, but it used to work well up untill now. It is best that you sign out of Netflix, and use something else to stream Netflix on, like a Roku tv.
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 5,520
