The PSP-3000 is the most recent update of the PlayStation Portable Series. A new pixel layout of the LCD screen and the newly installed microphone are the chief additions.
Device won't turn on
No charge
If the power adapter was not completely plugged into the wall or console, the battery won't be charged. Try charging the device again to make sure.
Bricked
Devices become bricked when the operating system is corrupted, which can be caused by turning off the console while upgrading the operating system or improperly installing third-party software.
If your PSP no longer starts up, and you're certain your battery and and power adapter are functional, then it may be bricked. Fixing a bricked PSP 3000 console without returning the console to Sony will require a new motherboard.
Bad power switch
If you're battery is charged, but the device still doesn't turn on, the power switch board may be damaged. You can replace it with a new power switch board.
Bad display
If your PSP turns on but the screen is blank, white, or distorted, the LCD may be damaged and require replacement. You can purchase a new LCD screen from our game console part store.
Bad motherboard
If you PSP 3000 will not turn on, but you have ruled out battery charging issues, you may have a damaged motherboard. You may follow the PSP 3000 motherboard replacement guide to check for any obvious problems (cracked solder joints, damaged components, etc.) and attempt to repair them, or choose to replace the motherboard.
Battery won't charge
Bad AC power adapter
If your power adapter is bad, the PSP won't charge. You can determine whether you have a bad adapter by charging your PSP 3000 using a functional adapter. If your PSP accepts a charge then you need to replace your power adapter. If the same problem occurs with a different power adapter then your device could be bricked or have a bad battery.
Device shuts off after unplugging the power adapter
Battery
If your battery is dead, the device will run fine off the power adapter, but will turn off when unplugged. The battery may not accept a charge, the device may not recognize the battery, or the battery may be recognized as charged but fail to power your device. A device with a faulty battery may also display "External" in the battery information even when the battery is in and the orange charging light is showing. In any case the battery would need to be replaced.
No sound
The device is on, the volume is turned up, but there is no sound.
Speaker
It is possible that you have a bad speaker or a faulty connection. Use the teardown guide to expose the speakers and make sure they are touching the motherboard contacts). If the connection is not the problem then the speaker itself may be faulty, in which case you will need to replace it.
Trigger buttons don't respond
If the trigger buttons don't respond then follow the trigger button guide to expose the buttons. Sometimes junk can become jammed under the trigger button and may need to be removed.
If that doesn't solve the problem, check the ribbon cable that connects the trigger pad to the motherboard. Re-connect any noticeably loose cables. It may also be helpful to clean the connectors with with a cloth.
Buttons stick
If the PSP D-pad or action buttons seem to be slow or unresponsive, they may just need a good cleaning. In order to clean the controls, remove the faceplate from the PSP and use compressed air to blow accumulated dust out from behind the keys. If the buttons are damaged, you can replace them easily.
Loose Analog Stick
Analog sticks have a tendency to become loose and unresponsive. The easiest solution is to purchase a new analog stick replacement.
The analog sticks, while similar in appearance, have small design variations between each model of PSP and are not interchangeable. Be sure replace the analog stick that corresponds to your PSP.
Games won't load
Your PSP will not boot games, gives disc-read error, and/or spins and loads continuously.
Bad disc (UMD)
Make sure that the disc is not scratched or dirty. Also, check that the disc is properly inserted into the drive. Before attempting repair, try a different disc to determine if the problem lies within the PSP or the UMD. If the PSP loads other discs, replace the disc that will not load.
Broken UMD trigger
If the white trigger on the inside of the UMD drive (opposite of the laser) is noticeably broken, the PSP will not read the disc. This trigger is attached to the motherboard.
Dirty/bad laser
If the disc or UMD triggers are not at fault, the UMD laser may just be dirty. With a q-tip and some isopropyl (rubbing) alcohol, open the back door where the disc goes and gently clean the laser head. Dry off the laser with the other end of the q-tip. Test and see if it works on a number of discs. If the PSP is still unable to load discs, the laser may be faulty. You can replace the UMD drive to restore your PSP.
Matthew Newsom
crwdns2935283:001/05/10crwdne2935283:0
43,117 crwdns2915208:0crwdne2915208:0
crwdns2935297:067crwdne2935297:0
crwdns2944067:058crwdne2944067:0
my psp 3004 does not what to update at all can someone help
raymond - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My psp doesn’t seem to accept a charge from my (offbrand) battery, which will be replaced. But if I take out the battery and try to charge and play which I used to be able to do, it won’t turn on. Recently my (offbrand) charger was accidentally kneeled on by my brother, causing it to unplug. It still worked for 2-3 days, until now. I have tried usb charging which is turned on but it won’t work. I would love to know what is wrong with my system as I would hate to let $90 go to waste (b-day present purchased two weeks ago). Thanks in advance!
Abstract_2 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
do you fix it already ? its the same problem as i have .
Niko Dural - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
If anyone wants to know how I fixed mine, I replaced my charger and battery (both off brand) which both went faulty in 3 weeks... Be careful when buying new batteries and chargers!
crwdns2936751:024crwdne2936751:0 22
crwdns2936753:07crwdne2936753:0 150
crwdns2936753:030crwdne2936753:0 628
crwdns2959996:0crwdne2959996:0 196,415
