The Sound Is On One Side Only
The sound is reaching only one speaker.
Check Cartridge
The stylus may be worn out if the sound is not functioning properly. If this is so, replace the cartridge.
RCA Audio Cord Connection
Make sure both speakers are hooked up properly. Check that the red RCA plug is connected to the red RCA jack labeled "R" (this indicates the Right speaker). Next check that the white RCA plug is connected to the white RCA jack labeled "L" (this indicates the Left speaker).
If need more assistance see Cable Set Up
Damaged RCA Audio Cord
From misuse, the RCA audio cord may be damaged. If so, replace cord.
Damaged Audio Jacks
If none of the above suggestions helped you might need to replace the audio jacks.
Target Light Glows Inconsistently or Not at All
The target light is malfunctioning.
Check Target Light Lamp
If the target light lamp is burned out, replace the entire target light with a new one. Target Light installation
The Output Sound Exhibits Excessive Hum or Buzzing
The sound is malfunctioning, making it hum or buzz.
Check Turntable Grounding Wires
If the turntable grounding wires are not connected, connect them to their respective Ground Lug on the equipment.
Turntable is skipping
If the turntable is skipping check the following things:
Check Surface
Check the surface that the turntable is on to make sure it is level.
Damaged/Broken Cartridge
The cartridge may have a defect and need to be replaced.
Excessive Force Applied on Platter
For optimal playing, make sure there isn't too much force applied on platter.
Record is Warped
The turntable could be skipping due to damaged records. Check records and replace damaged records if this is the case.
emmohneysd
crwdns2935283:010/12/11crwdne2935283:0
28 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 17-14, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 17-14, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S17G14
crwdns2935297:084crwdne2935297:0
turntable dragging not consistent speed (direct drive)
Steve Ledbetter - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 35
crwdns2959996:0crwdne2959996:0 2,340
