Flip over the turntable and remove the nine screws on the outer edges.
Find the audio jacks located on the back side of the turntable.
Remove the screw located in between the right and left audio jacks.
Remove the back cover by pulling it apart.
Remove the grounding hardware located next to the audio jacks.
Remove the screw located on the back panel of the audio jack housing.
Remove the screw that connects the audio jacks to the biggest circuit board via wire.
Gently pull out the audio input jacks from the audio input housing.
