Phone won't turn on
The phone does not show any light on the screen and does not respond when you press the red button.
Reset your phone
If you try to turn the phone on by pushing the red power button and it does not turn on, hold down the power button for 30 seconds to reset the phone.
Dead Battery
If your battery is dead, the phone may run on the charger, but not by the battery alone. After an hour of charging, if the phone does not work when unplugged, it is likely the battery is not holding charge and must be replaced.
Broken Power Button
Check the connection between the power button knub and the circuit board. If this is still a tight connection the circuit board may be fried, and will need to be replaced.
Screen failure
Cracked LCD Screen
If the LCD is visibly cracked, then you must replace the screen.
Screen shorting
Signs of screen shorting include sudden cutting out or failure to light up when the phone is on. Unfortunately this is usually a sign that the screen itself needs to be replaced.
The other problem could be that the circuit board shorted and it needs to be replaced.
Dead Circuit Board
The circuit board can fry and no longer interface with the screen, rendering it inoperable. This would mean that the circuit board would need to be replaced.
Buttons don't work
A button is pressed and the desired response is not achieved.
Buttons are stuck
The button simply isn't traveling to contact the sensor. Try pressing the buttons again, and harder. If that doesn't work, pop the front case and make sure that the buttons are in contact with the sensor and if not stuck to it, replace the the keypad.
Button is not connecting with sensor
If the buttons travel when pressed, but they don't connect to create the desired result. To fully check for this, you must open the case and check the sensor bumps on the back of the keypad. These bumps should be in contact with the sensors in order to work. Usually if this is the cause of the button failure, you must replace the keypad.
Circuit Board Failure
If the buttons do not work, even though they connect to the sensors, and the sensors have a clear connection to the circuit board, the board itself may not be working. This means that the next step would be to replace the circuit board.
Phone Won't Vibrate
Vibrator Motor Broke
If the phone does not vibrate when it is on the "vibrate" volume setting, then the vibrator motor must be replaced. The vibrator motor is soldered onto the back of the circuit board, and as such, the easiest way to replace it is to replace the circuit board.
No Sound is Coming Out of the Speaker
Blown Speaker
If no sound is coming out of the speaker when there should be, then the speaker needs to be replaced. The speaker is located behind the circuit board.
Andrew Wood
crwdns2935283:010/05/10crwdne2935283:0
348 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-52, Amido Fall 2010 crwdns2935289:0Cal Poly, Team 7-52, Amido Fall 2010crwdne2935289:0
CPSU-AMIDO-F10S7G52
crwdns2936753:030crwdne2936753:0 54
crwdns2959996:0crwdne2959996:0 6,726
