Nokia 2610 Circuit Board Replacement
    1. Nokia 2610 Circuit Board Replacement, Battery and Sim Card: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 2610 Circuit Board Replacement, Battery and Sim Card: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 2610 Circuit Board Replacement, Battery and Sim Card: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Place your thumb on the middle of the back cover and push it toward the bottom of the phone to slide the cover off.
    2. Nokia 2610 Circuit Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 2610 Circuit Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 2610 Circuit Board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a plastic opening tool (or your finger) to gently pry the battery out of the battery slot on the back of the phone.
    3. Nokia 2610 Circuit Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 2610 Circuit Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 2610 Circuit Board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the metal sim card holder (at the bottom of the battery slot) up and carefully pry the sim card out of its slot with a plastic opening tool or your finger.
      • After removal, lower the metal sim card holder into its original position.
    1. Nokia 2610 Circuit Board Replacement, Front Pannel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 2610 Circuit Board Replacement, Front Pannel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the plastic opening tool into the crack between the front and back panels.
      • Gently pry the front cover away from the back cover while sliding the plastic opening tool towards the top of the phone.
    2. Nokia 2610 Circuit Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nokia 2610 Circuit Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the bottom of the front cover away from the phone.
      • Continue lifting until the top of the front cover is fully removed from the phone.
      • Note: To replace the Keypad, gently lift it out of the front cover. It is located below the clear viewing window.
    1. Nokia 2610 Circuit Board Replacement, Circuit Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the Torx screwdriver with the T6 attachmet to remove the 6 .4 mm screws around the outside of the circuit board.
      • Note: Removing the 4 T6 screws around the screen will loosen it, so don't worry if the screen also separates from the circuit board.
    2. Nokia 2610 Circuit Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nokia 2610 Circuit Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nokia 2610 Circuit Board Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the circuit board out of the back cover.
crwdns2935229:05crwdne2935229:0
Andrew Wood
crwdns2935283:010/05/10crwdne2935283:0
336 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-52, Amido Fall 2010 crwdns2935289:0Cal Poly, Team 7-52, Amido Fall 2010crwdne2935289:0
CPSU-AMIDO-F10S7G52
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 3,724
