crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
P510 won't turn on
You press the 'on/off' button but the 'on/off' button remains unlit, the LCD screen doesn't display anything, and you can't take pictures
Bad Motherboard
If you have replaced the battery and still the 'on/off' button remains unlit, then it is likely the motherboard has gone out. We have instructions to help with the Nikon Coolpix P510 Motherboard Replacement.
Bad LCD Screen
If the 'on/off' button turns green, but the display remains unlit you likely have a bad LCD. We have instructions on the Nikon Coolpix P510 LCD Replacement.
P510 has been dropped and damaged
You have dropped your camera and now there is a crack in the lens, can't see anything when looking through the camera, or the camera outside has been cracked
Can't see through the lens to take pictures
If you can't see through the lens, or see a crack when looking through it, the lens assembly will need to be replaced. We have step by step instructions to help with the Nikon Coolpix P510 Lens Assembly Replacement.
Cracked outer lens casing
If the outer casing to the lens has been cracked in any way, we can help you replace it. These instructions will help with the Nikon Coolpix P510 Lens Casing Replacement.
Cracked LCD screen window
If the outer window of the LCD has be cracked or scuffed up, we can help you replace it. These instructions will help you with the Nikon Coolpix P510 LCD Screen Window Replacement.
Aaron Lamatsch
crwdns2935283:003/11/15crwdne2935283:0
146 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Colorado Springs, Team 2-2, Panko Spring 2015 crwdns2935289:0Colorado Springs, Team 2-2, Panko Spring 2015crwdne2935289:0
UCCS-PANKO-S15S2G2
crwdns2944067:022crwdne2944067:0
dropped and now is not charging or not switching on
abbasalhussaini - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Nikon coolpix 520 - working perfectly well but now is not charging and it does not switch on. probably due to slight drop.
Nikon Coolpix 520 - not charging and will not turn on. Not able to update firmware due can't turn on. How do I jump start this unit to fix software. Issue is not at all helpful.
Ewan Robertson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My Coolpix P510 switches on, but after about few seconds switches off again without any warning. Batteries are new (Lithium). Can any one please advise what is wrong with it?
Renier Coetzee - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hello Renier, did you find the solution of your camera issue. I have exactly same issue want to know how you fixed yours.
Thanks
Nadeem - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 69
crwdns2942667:0crwdne2942667:0 18,229
