If you are having issues with your LCD, this guide will help you replace it with a minimal effort. This part is easy to get to, and easy to replace. Other than a screwdriver and a plastic opening tool, nothing else is needed to accomplish this.
Flip the camera over and push the tab on the battery cover to open the battery compartment.
Push the little yellow tab to allow the battery to slide out.
With the tab pushed out, pull the battery out.
Extend the LCD screen out and turn the camera upside down to get access to the screws on the bottom.
Take the four 4mm PH00 Phillips screws out.
Use a plastic opening tool to trace around the screen to pop the front and back section apart.
Tilt the LCD up to get access to the back of it.
Unplug the ribbon cables on the side of the chip under the LCD by simple pulling lightly on them.
The chip has an adhesive on it to keep it attached to the LCD, and you will need to use a plastic opening tool to get it off.
Esse LSD tem outro fita preta que conecta pode estar ruim
Leonardo Silva - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Porque a minha não sei se ela é LCD ou esse negócio preto que conecta que tá ruim
