crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
The headphones don't work
When you plug in your headphones, sound does not come through them.
The volume is turned all the way down
Be sure to check that your phone does not have the volume turned all the way down. Use the side buttons to change the volume.
The headphones are broken
Your headphones might be broken, try a different pair.
The headphone jack is damaged
Try multiple headphones that work with other devices, if there is still no sound coming out of the headphone, the headphone jack might be damaged. If the headphone jack is damaged you will have to replace the headphone jack.
The phone won’t turn on
The phone won’t turn on, no matter what you try.
The battery is dead
If the phone will turn on only when plugged in, the battery might be dead. You can replace the battery.
The motherboard is damaged
If the phone will not turn on even when plugged in, the motherboard might be damaged. You can replace the motherboard.
Front facing camera doesn’t work
Images taken by the front facing camera, come out blurry or are just black.
Something is over the camera, or the camera is dirty
If the pictures you take are blurry or black, check to make sure there is nothing covering the camera. Wipe the lens off gently with a cloth to make sure it is clean.
A software issue is prevents the camera from working properly
If the pictures you take are blurry or black, a software issue might be preventing the camera from performing correctly. Try setting your camera to "default."
The front facing camera is broken
If the pictures you take are blurry or black, and there is nothing over the camera, and the problem is not a software issue, the camera might be broken. You will need to replace the fron facing camera.
Rear facing camera doesn’t work
Images taken by the rear facing camera, come out blurry or are just black.
A software issue is preventing the camera from working correctly
The rear facing camera is broken
If the pictures you take are blurry or black, and there is nothing over the camera, and the problem is not a software issue, the camera might be broken. You will need to replace the rear facing camera.
The phone crashes or turns off unexpectedly
The phone crashes unexpectedly and you can’t figure out why.
The phone crashes when a specific application is used
If the phone crashes when an application is opened, the application might be causing the problem. You can update the application or delete it to try to fix the problem.
A software issue is crashing the phone
If the phone crashes unexpectedly, this might be caused by other software issues. Be sure to have your system up to date. You can also try to switch back to default preferences in the system settings of the phone.
If you find no other explanation why your phone crashes unexpectedly, your motherboard might be damaged. You will have to replace the motherboard.
Victor Lopez
crwdns2935283:001/12/15crwdne2935283:0
509 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Cal Poly, Team 70-3, Forte Winter 2015 crwdns2935289:0Cal Poly, Team 70-3, Forte Winter 2015crwdne2935289:0
CPSU-FORTE-W15S70G3
crwdns2935297:084crwdne2935297:0
crwdns2936753:030crwdne2936753:0 90
crwdns2959996:0crwdne2959996:0 11,370
