crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
WiFi Connection Issues
Tablet is unable to connect to the internet.
WiFi is not enabled
WiFi must be enabled in settings for the tablet to communicate via Wifi. Try pulling down the notification bar and turing on WiFi in the quick settings pane.
Airplane mode is enabled
If airplane mode is enabled, your device will not be able to access the internet. Check to see if airplane mode is on by pulling down the notification bar. If it is on, tap its icon to turn it off. Make sure that WiFi turns on afterwards.
Notification LED not working
The notification LED will not flash when new notifications are received.
Software Issue
Bugs in the device's software may occasionally cause the notification LED to stop working. Try restarting your tablet. If this does not fix the issue, attempt to update Android through the Settings app.
LED is Broken
If the issue isn't resolved by restarting the tablet or updating Android, the LED is likely broken and needs to be replaced. As the notification LED is a part of the display assembly, disassemble the tablet and replace the display with this guide.
Random Rebooting or Freezing
The tablet crashes or freezes sporadically.
Location Services Causing Instability
Bugs in Location Services can cause crashes. Try turning off location services through Settings.
Android Should be Updated
Older versions of Android may contain unfixed bugs. Try updating your Nexus through Settings > Update Software > About tablet > System updates > Check for update. If an update is available, download and install it.
Tablet Will Not Power On
The device is not responsive and the display will not turn on.
Battery Not Charged Sufficiently
If your device's battery is not charged, it will not be able to turn on. Plug it in to a working charger for a while and try again after several minutes. This tablet was made for the Nexus brand by Samsung—so the charger is a Samsung tablet charger, usually branded Samsung.
Battery Needs to be Replaced
Your device's battery may need to be replaced. If it does not turn on after charging, try replacing the battery with this guide.
Combination USB Power / Audio Jack Assembly is Faulty
If your battery is completely dead and won't charge, and you are using a known good charger, you may need to replace your tablet's charging port assembly.
Cannot Connect to Camera
The camera app closes almost immediately after opening or will not open at all.
Software Issue
Most camera problems are caused by bugs that can be remedied with a reboot. Reboot the device by holding down the power button for several seconds and selecting "reboot".
Hardware Issue
If the front facing camera is scratched or damaged it may need to be replaced. You can find the steps to replace the front-facing camera with this guide.
Connor Steele
crwdns2935283:004/11/16crwdne2935283:0
431 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Cal Poly, Team 34-18, Maness Spring 2016 crwdns2935289:0Cal Poly, Team 34-18, Maness Spring 2016crwdne2935289:0
CPSU-MANESS-S16S34G18
crwdns2944067:04crwdne2944067:0
I keep getting the msg. "unfortunatley Google Play services has stopped and the process com.google.process.gapps has stopped. I have not been able to get my Nexus to work due to this. Any suggestions?
Rita Flora - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
How can I get my nexus 10 updating sylbol notification to diapear after turning the updating nitification turned off in the play store turned off the sylbol does disappear!
Rose Willis - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Turn off notification sylbol at the top of the screen on my nexus 10 tablet after turning off notifications for updating in play store it remains on the top of my screen tryed every thing plz help!!
I have reset my tab still my tab is unable to detect any of the wifi connections available. please suggest what i can do to??
simran2602arora - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 19
crwdns2936753:030crwdne2936753:0 110
crwdns2959996:0crwdne2959996:0 5,228
