Nexus 10 Display Replacement
crwdns2869540:0crwdne2869540:0: 9.5K
3
29
117
9,515
crwdns2955950:0crwdne2955950:0: 14
crwdns2960004:010crwdne2960004:0, crwdns2960008:04crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 6
crwdns2959974:06crwdne2959974:0
crwdns2955944:0crwdne2955944:0: crwdns2931273:0crwdne2931273:0
    1. Nexus 10 Display Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nexus 10 Display Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nexus 10 Display Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
    2. Nexus 10 Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
    3. Nexus 10 Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nexus 10 Display Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nexus 10 Display Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
      • Pull the the plastic backing off the display assembly using your hands.
      • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
    4. Nexus 10 Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nexus 10 Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nexus 10 Display Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Detach the three connector ribbons passing over the battery using the plastic opening tool.
    5. Nexus 10 Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
    6. Nexus 10 Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nexus 10 Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect the battery by lifting it upward and pulling it away from the connector.
    1. Nexus 10 Display Replacement, Headphone Jack: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove one screw on the logic board with a PH00 screwdriver.
    2. Nexus 10 Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nexus 10 Display Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nexus 10 Display Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Disconnect right speaker connector ribbon from logic board.
      • Lift the speaker out by pulling up on its corner.
    3. Nexus 10 Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nexus 10 Display Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nexus 10 Display Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Disconnect connectors around the perimeter of the motherboard.
    4. Nexus 10 Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nexus 10 Display Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove motherboard by gently pulling upward under its corner.
    5. Nexus 10 Display Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
    6. Nexus 10 Display Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nexus 10 Display Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
    7. Nexus 10 Display Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nexus 10 Display Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
    8. Nexus 10 Display Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nexus 10 Display Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
    1. Nexus 10 Display Replacement, Display: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nexus 10 Display Replacement, Display: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Detach LCD connector ribbon by pressing upward on connector latch using a plastic opening tool.
    2. Nexus 10 Display Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Nexus 10 Display Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the two 2mm Phillips #00 screws holding the ribbon in place.
      • Remove the board by tilting it forward and pulling outward.
    3. Nexus 10 Display Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove second speaker by gently tilting and pulling upward.
    4. Nexus 10 Display Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nexus 10 Display Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nexus 10 Display Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew the two 2mm screws securing the micro HDMI connector with a #PH00 screwdriver.
      • Remove the connector by liberally applying upward pressure.
    5. Nexus 10 Display Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Nexus 10 Display Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Nexus 10 Display Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew the 2mm Phillips #00 screw that holds the flash enclosure.
      • Remove the flash assembly with a plastic opening tool by lifting the assembly upward.
Benjamin Troller
crwdns2935283:004/11/16crwdne2935283:0
2,239 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 34-18, Maness Spring 2016 crwdns2935289:0Cal Poly, Team 34-18, Maness Spring 2016crwdne2935289:0
CPSU-MANESS-S16S34G18
I’m waiting for the instructions regarding how to remove the old screen and insert the new - it seems to be missing
John Walker - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
It seems you just have to buy a replacement for that whole front housing, including the screen assembly
Oliver Nichol - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Still waiting to see how the screen is remove
Frank - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
he cambiado la bateria y he partido el presor negro del conector de LCD y no me me funciona, se puede comprar esa pieza negra?
Diego Mera - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 117
crwdns2959996:0crwdne2959996:0 9,515
