crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
The device is not turning on
The device does not turn on when the power button is pressed.
The battery is no longer holding charge
If the device turns off immediately after being turned on, or doesn't turn on at all, then the battery may be unable to recharge any more. To put in a new battery, please refer to our Battery Replacement Guide.
The buttons are functioning irregularly
The device does not recognize use of the buttons correctly.
Buttons are worn out
If the buttons are slowly popping up or staying stuck down, then dirt or other small particles may be stuck beneath the buttons. To access the buttons for cleaning on the front of the device, please refer to our Front Buttons Replacement Guide. If you instead need to access the trigger buttons on the outside of the device, please refer to our Back Buttons Replacement Guide.
The buttons are unresponsive
If the buttons are not functioning when pressed, then they may need to be replaced. To replace the buttons on the front of the device, please refer to our Front Buttons Replacement Guide. If you instead need to replace the trigger buttons on the outside of the device, please refer to our Back Buttons Replacement Guide.
The circle pad is functioning irregularly
The circle pad is miscalibrated or not functioning.
The circle pad is no longer calibrated
If the screen is scrolling while the circle pad appears to be in the neutral position, It may need to be recalibrated. To recalibrate the circle pad, refer to [http://|Nintendo’s circle pad calibration steps].
The circle pad is broken
If the circle pad isn’t registering user input on your device, then it may need to be replaced. Please refer to our Circle Pad Replacement Guide.
The upper screen is black when the device is on
The upper screen doesn't turn on the despite the device being turned on
The upper screen is broken
If your upper screen still appears black when the device is powered on, then your upper screen likely needs to be replaced. To access and replace the screen, please refer to our Upper Screen Replacement Guide.
The touchscreen display is unresponsive
The touchscreen doesn’t register touch input.
The touchscreen is broken
If the touchscreen does not respond to input as expected when or appears black when the device is on, then it may need to be replaced. To access and replace the screen, please refer to our Touchscreen Replacement Guide.
Tim Newman
crwdns2935283:009/25/17crwdne2935283:0
2.075 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S18-G6, Forte Fall 2017 crwdns2935289:0Cal Poly, Team S18-G6, Forte Fall 2017crwdne2935289:0
CPSU-FORTE-F17S18G6
crwdns2935297:048crwdne2935297:0
crwdns2944067:07crwdne2944067:0
New 2DS XL. touch screen was unresponsive. Took a firm piece of card, wedged it between screen and bevel with quite a bit of force, slid it all the way around couple of times. Worked!
Try it before replacing or taking apart.
B Franklin - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
You are a genius my dude, this also worked for me, sorry for necroing this but you're the bomb.
Scott W - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Amiibo reader doesnt after dropping it. What do I do now?
Hamm Khan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have had a problem that my device does not seem to be loading or that the battery does not seem to hold charge. When charging, the solid red light won't turn off and when starting the device without charger attached it flashed red. I thought the battery was broken and ordered a new one, but the problem was another: the battery wasn't calibrated! YES, you can calibrate the battery. To do so, charge your device for several hours without interruption. Then detach charger and start your device. Drain the battery empty, for example by starting a game in full brightness and simply let the trailer run for several hours. When it shuts down due to drained battery, attach the charger and charge it uninterrupted for several hours until you're sure, it is completely charged. This calibrates the battery and for me the problem was gone.
dlxqdrt - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
i have problem when my 2ds xl just turn blue and red when i put new boot.frim and boot.3dsx it still do blue and red what i do
deven stewart - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 44
crwdns2936753:030crwdne2936753:0 159
crwdns2942667:0crwdne2942667:0 13,967
