Motorola V60 Troubleshooting
Motorola V60 won't turn on
You have tried everything, and the phone still won't turn on.
Press and hold the End/Call button
If the phone is still unresponsive read on.
Drained battery
Plug the phone into its respective charger and hold the "End/Call" button. If the phone responds, the phone needs to be charged.
Bad battery
Bad batteries can be a result of many different things. If the battery is bad, it needs to be replaced. To replace the battery see the Battery Replacement Repair Guide.
Bad display
If both the front and inside display are broken the phone may be turning on, but it will be difficult to tell. If this is the case, the displays may need to be replaced.
Bad logic board
If all previous steps were unsuccessful, the logic board on the phone may be broken. If this is the case the logic board may need to be replaced. To replace the logic board, see the Logic Board Replacement Repair Guide.
Motorola V60 buttons won't respond
If one or more buttons are unresponsive, read on.
One or more buttons stick
If this is the case follow the Button Board Replacement Repair Guide.
All buttons are unresponsive
If none of the buttons work, the logic board may need to be replaced. See Logic Board Replacement Repair Guide.
Speaker or microphone does not work
When you receive a call, you are unable to hear the caller or vice versa.
Call waiting
Press the green Send/Call call button to see if you accidentally put the caller on call waiting. If this is not the case read on.
Bad speaker or microphone
The speaker or microphone may need to be replaced.
Bad logic board
If the speaker or microphone is still unresponsive after replacement, the logic board may need to be replaced. See Logic Board Replacement Repair Guide.
Headphones produce unclear or no sound
When you plug in headphones to the headphone jack, they produce unclear/no sound.
Bad headphone jack
If the headphone jack is broken, the logic board needs to be replaced. See Logic Board Replacement Repair guide.
John Abruzzini
crwdns2935283:001/21/10crwdne2935283:0
7 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Cal Poly, Team 8-48, Regan Winter 2010 crwdns2935289:0Cal Poly, Team 8-48, Regan Winter 2010crwdne2935289:0
CPSU-REGAN-W10S8G48
crwdns2935297:084crwdne2935297:0
crwdns2942667:0crwdne2942667:0 2,214
