Screen Goes Black
Nothing is visible on the screen.
Battery Issues
Your battery may have died. If the phone does not work when the battery is fully charged or when the phone is plugged in, it may be necessary to replace the battery. To properly open up the phone and replace this, refer to the Motorola RIZR Z3 Battery Installation Guide.
Broken LCD
Your LCD might be broken. To replace the LCD, refer to the Motorola RIZR Z3 LCD Installation Guide to replace your LCD.
Faulty Motherboard
The motherboard may be dysfunctional. To replace the motherboard, refer to the Motorola RIZR Z3 Motherboard Installation Guide.
Buttons Won't Work
Pressing the buttons does nothing.
Buttons Not Fully Depressed
Make sure that you are pressing the buttons down completely.
Bad Connections
The key may not be making contact with the motherboard. To properly open up the phone and repair or replace the motherboard, refer to the Motorola RIZR Z3 Motherboard Installation Guide.
Center Select Button Comes Off
The circular center button falls off of the phone.
Bad Adhesive
The adhesive that holds the center button can deteriorate with time. A small dab of superglue will effectively hold it in place.
Push Bar Comes Off
The plastic push bar under the screen breaks off.
Bad Adhesive
The glue holding the push bar can deteriorate with time. A little dab of superglue will effectively hold it in place.
Phone Turns Itself Off
My phone deactivates itself on its own.
Sleeping Phone
Press the power button. It is possible that the phone is just sleeping and the screen has turned black to conserve battery power.
Faulty Motherboard
The motherboard may be dysfunctional. To properly open up the phone and repair or replace the motherboard, refer to the Motorola RIZR Z3 Motherboard Installation Guide.
Camera Does Not Work
When I go to take pictures, camera mode is completely black.
Camera Damage
The camera lens may be cracked, or there may be internal problems due to water damage. To properly open up the phone and repair or replace the, refer to the Motorola RIZR Z3 Camera Installation Guide.
None of The Above
Nothing listed above applied to or worked for my device.
If your problem wasn't listed here, someone will be able to answer your questions on the Motorola RIZR Z3 Question Page. The user manual, located here, is another resource that may hold your solution.
Andrew Brock
crwdns2935283:010/07/11crwdne2935283:0
8 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-34, Amido Fall 2011 crwdns2935289:0Cal Poly, Team 5-34, Amido Fall 2011crwdne2935289:0
CPSU-AMIDO-F11S5G34
crwdns2942667:0crwdne2942667:0 2,037
