Motorola RIZR Z3 Camera Replacement
    1. Motorola RIZR Z3 Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola RIZR Z3 Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
    2. Motorola RIZR Z3 Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola RIZR Z3 Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Tilt the battery by lifting at the exposed notch.
      • Slide the battery out of its casing.
    1. Motorola RIZR Z3 Camera Replacement, Motherboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
    2. Motorola RIZR Z3 Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola RIZR Z3 Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a plastic opening tool to lift the plastic casing.
      • Pull the plastic casing directly away from the phone.
    3. Motorola RIZR Z3 Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the black rubber loudspeaker housing up and out of the plastic casing.
    4. Motorola RIZR Z3 Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola RIZR Z3 Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
      • Caution: Remove carefully, if broken, the phone will not be able to make calls.
    5. Motorola RIZR Z3 Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola RIZR Z3 Camera Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
      • Caution: Remove carefully, if broken, the phone will not function properly.
    6. Motorola RIZR Z3 Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Motorola RIZR Z3 Camera Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
      • Caution: Do this gently Unclipping too fast may cause damage to your phone.
    1. Motorola RIZR Z3 Camera Replacement, Camera: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the phone to the front.
      • Push the keypad out through the plastic casing.
    2. Motorola RIZR Z3 Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the phone to the side.
      • Thread the hinges of the slider through their holes in the casing and pull the slider down and away from the casing.
    3. Motorola RIZR Z3 Camera Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slip the plastic opening tool carefully between the camera and the plastic casing.
      • Gently pry the camera unit loose, being mindful of the adhesive that holds it in place and the copper colored ribbons that are attached to it.
Andrew Vu
crwdns2935283:010/07/11crwdne2935283:0
35 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-34, Amido Fall 2011 crwdns2935289:0Cal Poly, Team 5-34, Amido Fall 2011crwdne2935289:0
CPSU-AMIDO-F11S5G34
crwdns2942667:0crwdne2942667:0 1,085
