crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Camera Images are Distorted
Phone is unable to take pictures using the rear or front facing camera on the phone.
Rear or Front Facing Camera Lense is Cracked
A crack in the camera lense could cause images to be distorted. Examine the camera for any visible cracks on the surface of the lense. If cracks are present, refer to the camera replacement guide to resolve this issue.
Lens is Dirty
There could be a smudge on the lens of the camera. Use a soft polishing cloth to wipe the smudge off the lens.
Battery Does Not Charge or Dies Quickly
The phone dies quickly after being fully charged or does not charge at all.
Battery is Faulty
The phone's battery may be faulty if the phone does not hold a charge and dies quickly after charging. The phone may also die even though it says it is still charged. If these issues occur, the battery will need to be replaced. Refer to battery replacement guide to resolve this issue.
Charging Cable is Not Making a Connection
This may be the issue if the phone will not charge at all. The charging cable could be frayed or worn out, keeping it from charging the phone correctly. Check for any places where the wire is exposed or the cord is bent. If the cord is damaged, you may need to purchase a new charging cord.
Charging Port is Damaged
The charging port at the base of the phone could be damaged. First, ensure that the charging cable works properly. Then, plug the phone in with the good cable. If the phone still does not charge, the charging port may need to be replaced. Refer to the charging port replacement guide.
Charging Source is not Reliable
A phone will not charge if the port it is plugged in to does not work . Try using other outlets to ensure that the outlet is not faulty. Insert the prongs of the charger completely into the outlet to ensure a good connection. If the outlet is faulty, charge the phone in a different outlet.
Power and Volume Buttons are Not Responding
The power and volume buttons are not responsive when pressed.
Buttons are Dirty
Buttons may not respond if there is dirt or residue underneath them. To determine if this is the issue, open up the back of the case. If there is dirt, clean this out with a cloth and replace the back of the case.
Buttons are Faulty
First, make sure that the buttons are clean (see "Buttons are Dirty"). If the buttons are still not responding when pressed, it is likely that they need to be replaced. Refer to this button replacement guide for instructions.
Cannot Hear Other Person on the Line
User is unable to hear other person on the line.
Other Person's Phone is on Mute
Contact the other person and ensure that they have turned off the "mute" function on their phone.
Dirt is Built up on the Earpiece
If dirt has collected on the earpiece, one may not be able to hear through the phone microphone. The microphone is located at the top left corner of the phone. Obtain a soft polishing cloth and clean out this microphone.
Earpiece is Damaged
If the earpiece appears clean, but sound is still fuzzy or nonexistent there may be internal damage. Refer to earpiece replacement guide.
Screen is Unresponsive to Touch
The screen does not respond when touched. A part of the screen may be unresponsive, or the entire screen may not work.
Screen is Cracked
Check the surface the of the screen. If there are any visible cracks, the screen may need to be replaced.
Screen has Water Damage
If the touchscreen is not responding and there are no cracks, the most likely issue is water damage. This can occur when the phone is exposed to any level of moisture, not just when it is submerged in water. This issue can difficult to diagnose but is the most common cause of screen unresponsiveness after cracking. Replace the screen to remedy the water damage.
Paul Early
crwdns2935283:003/19/18crwdne2935283:0
365 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Baylor, Team S3-G2, Williams Spring 2018 crwdns2935289:0Baylor, Team S3-G2, Williams Spring 2018crwdne2935289:0
BU-WILLIAMS-S18S3G2
crwdns2944067:023crwdne2944067:0
bought my motorola e4 yesterday and i have set homescreen to sleep after 5 minutes but it wont stay lit up goes to sleep after 10 seconds and i think its a faulty phone. please help
las6178 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Cracked my Moto e4 screen. Got a replacement not need help changing
Steven Vasquez - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Need help replacing with cracked screen on myoto e4
i had a lg phone that worked great until the company shut it down just so no reason then i brought a new motoe4 and honestly it has the be the very worst phone i have ever own consider it the bmw of phones nice looking but nothing works for long if its not the date and time keeps droping or the phone calling numbers on its own or it shuts of even if you have it on 30 minutes i guess its made in china and china doen not care about quality only production sigh0000000 can any one help
tggxr - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My camera will not come on at all it says camera has stopped and camera keeps stopping
Opal Ruppe - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 33
crwdns2959996:0crwdne2959996:0 9,661
