crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Sound Quality is Poor
The sound quality diminished since the original purchase of the headphones.
One Speaker is Not Working
First, check to see if anything is blocking the speaker. If that is not the case, there may be a loose internal wire, or the speaker may need to be replaced.
You can see the wire replacement guide here: Monster DNA Wire Replacement
You can see the speaker replacement guide here: Monster DNA Speaker Replacement
The Headphone Loses Audio Connection
There is no audio or audio has stopped during playing.
Cord Connections
Make sure both ends of the cord are connected properly. Try using the jack in the other earpiece of the headphones to find out which jack is having the issue. Also, try plugging the headphones into a different device to see if the headphones are the issue.
Sound From Audio Jack is Cracked or Distorted
The audio is not what it is supposed to be.
A Faulty Audio Jack
The jack may need a good cleaning. First, dip a ear swab into Isopropyl alcohol. Then, rub the inside of the jack with the ear swab gently. Do not forget to allow enough time for the jack to dry before using it.
Headphones Are Not Fitting Properly
Are the headphones falling off your head, feeling awkward, or just looking bad?
Broken Headband or Other Plastic Parts
Any broken physical plastic parts can cause the headphones to fit improperly or fall off. You will need to use some glue to bind the broken pieces back together. Make sure you use a glue that is suitable for plastics. Do not forget to follow the glue manufacturer's instructions.
Ear Cushions Falling Out
Your headphones may be uncomfortable if one or both of the ear cushions have fell out from the earpiece. Use glue to follow the manufacturer's instructions first. The earpiece may need to be replaced if the above solution does not work.
You can see the ear cushion replacement guide here: Monster DNA Ear Cushion Replacement
Fhad Alkoize
crwdns2935283:009/26/15crwdne2935283:0
251 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
IUPUI, Team 2-1, Wilson Fall 2015 crwdns2935289:0IUPUI, Team 2-1, Wilson Fall 2015crwdne2935289:0
IUPUI-WILSON-F15S2G1
crwdns2944067:07crwdne2944067:0
I have the one cord headphones and the problem is I keep pulling them by accident and now my audio is alot lower and cant hear discord or skype
masterpasha - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
computer wont detect when my Monster DNA headphones are plugged in, replacing the cor with an AUX cord seems to work temporarily, but it works for a shorter period each time i buy a new cord
beans - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Is only 6 months old and. Don’t get any charge no matter if I plug in to the power for 24 hours
santamariajaime10 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Brand new and can't get the headphones to charge. I plug the into the power jack, red light comes on showing they are charging and than it goes off after 10 seconds. HAve tried plugging in elsewhere and get no charge. I did get the bluetooth part charged.
Tziporah - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I would like to connect my monster mth9-1001-blk to RCA tv digital audio output what do I need.
d.earl - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 22
crwdns2942667:0crwdne2942667:0 7,937
