Camera will not turn on
When you flip the power switch on, the camera does nothing
Power switch will not work
Verify that you have slid the power switch all the way to the "ON" marking when you tried to turn it on. Often, the switch is not slid all the way and that is why the camera will not turn on.
Battery is dead
If the batteries are dead or not in the camera, then you are going to have to replace them. The Minolta X-370 can run on three different types of batteries:
1) Two 1.55v silver-oxide (SR-44: Eveready S-76, EPX-76 or equiv.)
2) Two 1.5v alkaline-manganese (LR44 Eveready A-76 or equiv.)
3) One 3v lithium (CR-1/3N)
Film will not advance
After taking a photo, the camera will not advance the roll to the next negative so that you can take another picture
Film winding lever is stuck
The lever will not move if the shutter is already cocked. If the shutter is cocked, and will not release with new batteries INSERTED CORRECTLY. The camera will not work without power.
Film winding lever is loose
Verify that the rewind button is not stuck down. Open the back door and rotate the advance sprocket back and forth to release the button. If this does not work, take the bottom cover off and verify the white plastic gear near the take up shaft. If the gear is broken it will need to be replaced. You may also opt for removing and replacing the film winding lever if you'd like.
Shutter won't go off
The camera will not take a picture after pressing the "shoot" button.
The camera is not on
Verify the on/off switch has been fully slid into the "ON" position.
The lens is not attached properly
The X-370 will not take a picture unless the camera lens is inserted completely. To attach a lens, align the red mounting index on the lens barrel with the red index on the camera's lens mount. Insert the lens into the mount, and turn the lens clockwise until you hear a "click". This noise confirms that the lens has been mounted properly.
The battery is dead
The X-370 has a built in battery tester. After the camera has been turned on, press the "shoot" button half-way while looking through the viewfinder. On the right side of the viewfinder, there is a shutter speed scale and mode selection ("M" for manual, "A" for auto). If either an "A" or "M" show up, the battery is okay. If the "A" or "M" is flashing or does not show up, the battery is almost dead or already dead and will need to be replaced.
Viewfinder has spots
When I look through the viewfinder, I see dirt spots.
The viewfinder lens is dirty
Wipe the viewfinder lens with cleaning solution and a microfiber cloth. If there are spots directly on the viewfinder lens that cannot be removed, they will not affect the pictures.
The lens is dirty
Remove the lens and wipe the outer and inner glass with a microfiber cloth and cleaning solution. If there are scratches on the lens, they will be evident in your photos.
The mirror is dirty
Remove the camera lens and wipe the mirror with cleaning solution and a microfiber cloth. If you'd like to make the mirror more accessible, you may remove the lens holder.
Viewfinder meter does not show up
When I look through the viewfinder and push the shutter button half-way down, nothing lights up.
Verify that the switch is fully in the "ON" position.
The battery is low/dead
The X-370 has a built-in battery tester. After the camera has been turned on, press the "shoot" button half-way while looking through the viewfinder. On the right side of the viewfinder, there is a shutter speed scale and mode selection ("M" for manual, "A" for auto). If either an "A" or "M" show up, the battery is okay. If the "A" or "M" is flashing or not showing, the battery is almost dead, or already dead and will need to be replaced.
The voltage is not passing from the battery to the other parts of the camera
There could have been some corrosion which can migrate to the battery box contact wire and cause a resistance so that it will not pass voltage. This would cause the power from the battery to not reach all of the parts in the camera body, causing the light meter to not show up.
Munir
crwdns2935283:004/20/11crwdne2935283:0
77 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
EWB Thailand crwdns2935289:0EWB Thailandcrwdne2935289:0
Community
crwdns2944067:06crwdne2944067:0
What if the when you look through the view finder it's black and the shutter won't fire
I replaced the batteries and the camera is on, any ideas?
William - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I'm having the same issue. Did you ever find a solution?
Liz Pinto - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Same here. Did you find a solution?
Akim - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Turn the dial to ‘A’. That allowed me to see the red dots lighting up, but shutter still wont click for me.
Carlos Gonzalez - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
the batteries fell out so I put them back in and the film went back down from 0! is the film going to overlap now? does anyone know?
jenn.thomas - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 119
crwdns2959996:0crwdne2959996:0 49,468
