crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Surface won't turn on
No matter what you do, you can't get your Surface to turn on.
Solution-
1. Force Restart: Press and hold power button for 30 seconds. Screen may flash but do not release power button until 30 seconds is complete. Then press the power button again to turn the Surface back on.
2. Two-button Shutdown: Press and hold the power button on your Surface for 30 seconds and then release it. Press and hold the volume-up button and the power button at the same time for at least 15 seconds and then release both. Wait 10 seconds and then turn your Surface back on
Windows Is not Responding
Windows is not starting up on your Surface Pro 3.
Solution-
3. Install Surface and Windows Updates: Go to Start , and select Settings > Update & security > Windows Update. Select Check for updates. If updates are available, select Details. Select the updates you want to install, and select Install. Surface may need to be restarted.
4. Scan Surface with Windows Defender: In the search box, enter defender, and in the search results, select Windows Defender. On the Home tab, choose a scan option, and select Scan now.
Battery won't charge
Your Surface is plugged in but isn't charging
Your charger is not plugged in to your Surface
Check your charging port to make sure your charger is being plugged in correctly
Your battery is not detected
Solution-
Boot the system with the power adapter connected, by holding down the power button until the unit powers itself off. Then disconnect the power adapter from the unit. Press and hold the Power button and wait for a depleted system battery icon full screen. Reconnect the power adapter to the unit. Then press and hold the volume up and power button for 15 seconds. Finally, press and hold the volume up and power button until the keyboard lights up.
Your Surface only runs when plugged into the charger
This may mean that it is time to replace your battery. To replace the battery, follow this link to our battery replacement guide.
Wifi Connection Issues
Trouble connecting to the internet from your Surface Pro 3?
Run Troubleshooters
Click on your start menu, located on the lower left side of your screen. Click on the search box located in the menu. Search “Network Troubleshooter”, in the results you should see “Identify and repair network problems” click and follow the steps. It will try and fix any network issues that may be present.
Outdated Drivers
Try to install the latest updates on your surface to fix the issue. If you cannot connect to your home network try to connect to a public Wi-Fi connection. If you are unable to connect to a public connection. Connect to the internet using an ethernet connection. As a last resort, you might be able to use your phone’s internet connection by enabling the mobile hotspot option.
Date and Time Setting
Sometimes the issue can be the date and time setting. To fix this click on the icon located in the bottom right hand side of your screen’s toolbar. The icon contains the time and date. Click on the red highlighted text that says “Date and Time Settings” you can enable the set time automatically option or you could manually set it yourself.
Restart Wi-Fi on Surface
Click on your start menu icon located on the bottom left side of your toolbar. A menu will open up, you will then see a search bar located near the bottom left side of your screen. Type in there “Wi-Fi Settings” click on the “Change the Wi-Fi Setting” option. There you can toggle on/off the Wi-Fi. Choose the Wi-Fi connection you would like to connect to. If this still does not work try disconnecting completely from your Wi-Fi, by clicking on your connection and then clicking “disconnect” and connect back onto it. It will make you input your password again so make sure you know your Wi-Fi password before attempting this.
Manually Install the Driver
After attempting everything above, your Wi-Fi still does not connect then try manually installing your Wi-Fi drivers, follow this Microsoft guide to install wireless drivers.
Surface Pro Driver Installation
Bluetooth Connection Issues
Trouble connecting bluetooth device with your Surface Pro 3?
Run automated troubleshooter
You can also search for the ”Hardware and Devices Troubleshooter” program in the search box under the start menu. Follow the instructions that the program gives.
Check Compatability of your Bluetooth Device
Learn how to make your device discoverable by any other device, by reading their manual or website. Click on your start menu located on the bottom left corner of the your screen and click on settings, devices, bluetooth. When your Surface Pro 3 finds your bluetooth device click on pair.
Latest Drivers on Windows
Make sure you have the latest drivers on windows, by running the windows live updater. You can easily find this by typing in the search box “Check for Updates.” Then click on the “check for updates” button, this will start making sure your computer is up to date. Any updates it may still need to download will start downloading them automatically.
Overheating
If you have the Surface Pro 3 Core i7 version, you may have issues with overheating. The i7 version delivers great power into a small package, thus the device is prone to overheating. This problem has been associated with the running of Windows Installer Module and Windows Installer Module Worker. Shutting those two systems down is believed to cool your Surface Pro, but if not you will probably need to downgrade to i5 processor version.
Screen Problems
Your screen freezes at random times, your screen will not rotate, the touchscreen is not responding to touch, or your screen is broken.
Random Freezing
This can occur when switching apps, on the Start screen, or even when doing nothing. There is no common cause so pay attention when freezing occurs to see what the problem could be. Try holding down the Power button and the Volume up button for 15 seconds. Wait a couple of seconds and then press the Power button again and it will restart.
Screen Rotation
Follow this link to fix your screen rotation problems.
Touchscreen Problems
Follow this link to fix touchscreen problems.
Glitch- Cursor Disappears
Folding the Type Cover keyboard back is known for causing the cursor to disappear, and it refuses to return when the keyboard is flipped back around. Others have found that the cursor just disappears at random when they’re using the mouse.
Cracked Screen
Follow this link to fix your broken screen or digitizer.
Problems with SSD card
Look to our replacement guides to learn how to replace your SSD card.
Broken headphone jack
Make sure your headphone jack is clear and your head phones are being plugged in completely and properly. If this is not the case, follow this link to replace your headphone jack.
Erik Snyder
crwdns2935283:010/01/15crwdne2935283:0
5 460 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-18, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 12-18, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S12G18
crwdns2944067:085crwdne2944067:0
Surface pro won't start problem FIXED.
1. Charge the battery.
2. Press the on button very hard for 2 seconds and release it. Button have dirt inside.
3. If Surface start, adjust the power option plan to prevent off for sleep, power button and lid.
4. Put one drop of WD40 penetrating oil from the top of button to internally clean it.
5. Press the button 20-25 times to move the oil inside the switch.
6. Shoot down and start the PC normally. If not work, repeat step 2 (only) two or 3 times.
Wilson Roman - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
this probably isn’t recommended but I tried everything to get my surface pro 3 to turn on. nothing worked. I was so frustrated that I flexed the case forward and backward. heard the case grind a little. My surface immediately turned on. I am installing all updates now. I also turned off all sleep functions, hopefully I don’t have to deal with this again. This will never be my primary PC again though….
Michael Peterson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have tried everything as well and never had any luck to get it to turn back on.  I tried Michael’s suggestion of flexing the whole tablet forward and backward two or 3 times and it fired right up!!!
Aaron Baumgartner - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Wow, this just worked for me as well. I didn’t have to flex it harder than I thought it could take. Mine hasn’t been able to turn on for a couple of weeks. Tried everything I could find online. MS Store was no help (offered to sell me another surface). Thanks for posting.
Mark Hopkins - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Yes! I've tried everything and nothing worked, then saw these comments, flexed my surface back and forth a couple times and hit the power button and wham! Back to life!
Mike Redlegguy - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 90
crwdns2959996:0crwdne2959996:0 119,904
