crwdns2959928:0crwdne2959928:0 ↓This guide will teach you how to safely remove your battery from your Surface Pro 3. The guide starts by removing the screen and digitizer and then goes right into removing the battery.
To remove the display, first soften the adhesive by applying heat. You can use a heat pad, heat gun, or iOpener. In a pinch, a hair dryer can also work.
Steadily and evenly heat the perimeter of the display until it's too hot to touch, and try to maintain that temperature for several minutes.
Use a suction cup or an iSclack to pull up on the glass and create a slight gap between the glass and the metal frame.
Carefully insert an opening pick into the gap between the screen and the device to cut the adhesive.
Slide the pick around the sides and bottom of the display to cut the adhesive. Apply more heat as needed.
Continue to heat sections of the screen with the heat gun.
As you make your way around the screen with the heat gun, use the plastic opening tool and the opening picks to pry the screen loose.
Lift the screen up carefully so that no wires are torn.
Remove the 3 mm T3 Torx screw securing the battery connector, and disconnect the battery connector.
Remove the single 4 mm T3 Torx screw securing the display cable.
Lift the connector to disconnect the cable.
Grasp the orange cable connected to the silver connecter.
Carefully lift the orange cable up until the connecter pops off.
The screen will now be completely disconnected.
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Use the metal spudger to scrape the battery off of the device.
crwdns2935229:060crwdne2935229:0
crwdns2947412:035crwdne2947412:0
Do you have to glue everything back together? Do you heat the parts back up to get the glue to stick again?
Danny O'Boyle - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I slowly removed the old adhesive watching out for glass shards. A spundger and razer blade didn’t really help. In the end, I just used my fingernail and finger to roll the adhesive like I was removing rubber cement. It too about 30 minutes but I was able to get it cleaned off. I replaced the adhesive with 2 mm Tesa tape. This worked great.
michael jones - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Has anyone ever successfully opened a surface pro 3 without breaking the screen?
juliusmalexander - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Yes I have successfully open the surface pro with out breaking the screen by using a heat gun, the islack and the using the picks around the screen as anchors, then use the islack as you will use it to replace the screen in the iphone. It takes time and patience and a lot of heat. It took me 25 minutes to remove the screen with out breaking it.
computertechomar - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Only wizards can accomplish this task without breaking the screen. Yes the screen must be reheated for the glue to stick again. A simple fix to avoid all of these problems is to switch to Apple products.
Erik Snyder - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
