crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Microsoft Surface Book Troubleshooting
Released in October 2015, identified by the model numbers 1703 and 1705
This troubleshooting page will help you resolve issues with the Microsoft Surface Book.
Touchscreen Is Unresponsive
Device will not respond via touch.
Dirty Screen
Clean the screen, with a soft, lint-free cloth, slightly dampened with water. Do not apply water directly to the screen.
Restart Computer
Click on the windows icon in the lower left corner of your screen. Click on the power icon that is directly above of the windows icon. Choose the restart option.
Touchscreen Driver Is Unresponsive
Search device manager in the search bar next to the start button. Select the device manager result, and choose the arrow to the left of Human Interface Devices Right click HID-compliant touch screen and then select disable. Right click HID-compliant touch screen and then select enable.
Replace Screen
If non of the above solutions do not work, try replacing the screen. Microsoft Surface Book Screen Replacement
Laptop Is Running Slow
When the device is turned on, its applications take slow times to load.
Device Is Overheating
Consider moving your Surface Book to another surface that allows for better ventilation. Let it sit for five minutes, and if running a memory-intensive application, consider closing it for a few minutes to help it cool faster.
Low Disk Space
To check for low disk space, click on the windows icon in the lower left corner of your screen. Scroll down using the drop-down menu, and select settings. Choose system and then storage. Check the remaining space on the hard disk by selecting the :c drive. If running low on disk space, you need to clear unneeded applications and files to free up space.
The Screen Is Unable To Display Entire Images.
When images are launched on the device, parts of images are displayed. The rest are either faded or cut out.
Surface And Window Updates Out Of Date
Click on the start button in the lower left corner, settings, then Update & security, and Windows Update. Choose check for updates. Install any needed updates.
Display Scaling Needs To Be Changed
Click on Start then go to Settings>Display>Display. Using the slider bar, adjust the scaling percentage as needed.
Keyboard Doesn’t Function Properly
As each key is tapped, the letters won’t appear at the same time the characters are inputted. Only some characters show up on the screen once they are entered.
Keyboard Not Attached Properly
If the keyboard is not connected properly, the Detach key will flash green. Push the Surface Book down into the keyboard with a moderate amount of pressure.
Dirty Connectors On Detachable Keyboard
Using the highest possible isopropyl alcohol possible, cotton swab the silver connector pins on the keyboard. Ensure that you use a new portion on the cotton swab to clean both sides of the three connectors. Check that connectors are dry and free of cotton fibers.
Battery Will Not Charge
When connected to any charger that fits, the device will not charge.
Dirty Connectors On Power Supply
First, use a pencil eraser to clean the pins on the connector (that attach to the Surface). Then using a cotton swab wetted with isopropyl alcohol, clean the pins. Ensure that the pins are dry and free of cotton fibers.
Operating System Updates Are Out Of Date
Plug in your Surface. In the search bar next to the start icon, search device manager. Select Device Manager and the arrow next to the Batteries category. Double-click Microsoft ACPI-Compliant Control Method Battery and select uninstall. Click on the start icon, select Settings>Update & security>Windows Update. After you select Check for updates, it will automatically restart and update. If it fails to restart, select Start then Power then Restart.
Replace Battery
If none of the above solutions work, try replacing the battery. Microsoft Surface Book Battery Replacement
Speakers From Device Do Not Emit Sound
While playing an audio or video file, the sound is not heard from the device.
Speaker And Microphone Openings Are Obstructed
Check the speaker and microphone openings for obstructions. If present, remove them.
Volume Not Turned On
Make sure the volume is turned on. If not, use the buttons present on the Surface, on the keyboard (if present) or the desktop taskbar to turn the volume up. Some apps also have audio settings that may need to be adjusted.
Audio Accessories Like Headphones Don’t Work
Firstly, check your accessory with another device to ensure that the accessory works. Ensure that there is a tight connection between the accessory and the Surface Book. If the audio accessory uses Bluetooth, ensure that there is a secure pairing between the Surface Book and the device.
Wesley Kendrick
crwdns2935283:002/15/17crwdne2935283:0
2 339 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-6, Sullivan Spring 2017 crwdns2935289:0USF Tampa, Team 1-6, Sullivan Spring 2017crwdne2935289:0
USFT-SULLIVAN-S17S1G6
My Surface Book 2 is have an issue with the tablet portion connecting to the base. It attaches and detaches just fine but I'm still getting the troubleshoot icon on the detach icon in the task bar. I can visibly see a difference where the top connects to the bottom, as one side seems to be set back further slightly than the other. I tried detaching it and looking and the metal connectors and if they're bent I cannot tell. I have treated this laptop like a child and I don't think that this is an issue due to my use. But if so, I'd really appreciate some help fixing this.
Jebbus - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 33
crwdns2959996:0crwdne2959996:0 7,108
