The MacBook replaces the iBook, with an Intel Core Duo or Core 2 Duo CPU, magnetic MagSafe power connector, integrated iSight camera, and 13.3" widescreen display.
MacBook won't turn on
Your computer will not boot.
Bad power adapter
If your power adapter is bad, the computer will run off a battery, but it won't charge. If your battery is too low, it will be difficult to diagnose a bad power adapter. The easiest way to test this is to borrow either a battery or power adapter to test in your machine. If you have the same problem with another power adapter, your problem is most likely the logic board.
RAM issues
If your computer beeps three times, there is a RAM issue. Either you have insufficient RAM to boot, or the RAM you do have is faulty. First, access (Core Duo or Core 2 Duo) the RAM slots and ensure you have RAM installed. If you have two chips, first reseat them and try again. If that doesn't work, try one chip at a time to see if one of the chips prevents the machine from booting. If none of these work, you may have a bad logic board.
Bad DC-in board
If your DC-in board is bad, you will not be able to start your computer when it's plugged into the wall. It may or may not run on the battery and the light on the power adapter will not light up at all (some power adapters do not have lights, so this may not apply to your computer). If this is the case, you must replace (Core Duo or Core 2 Duo) the DC-in board.
Bad logic board
If replacing the DC-in board and battery doesn't fix your problem, then you need a replacement (Core Duo or Core 2 Duo) logic board. We carry logic boards for every MacBook model. There are some variations within specific processor speeds of MacBook logic boards. For example, the 1.83 GHz Core Duo logic board has 2 options: 3-wall or 4-wall heat sink connectors. The 2 GHz Core 2 Duo logic board has 2 options: Energy Star and non-Energy Star. Be sure to read the part description to ensure you are purchasing the correct logic board for your machine. Select your model for logic board options: Core Duo, Core 2 Duo (Late 2006), Core 2 Duo (Mid 2007), Santa Rosa, Penryn, or Early/Mid 2009.
Laptop shuts off when I unplug it
As soon as you unplug the computer from a power source, it shuts off.
Dead battery
If your battery is dead, the computer will run fine off the power adapter, but will turn off when unplugged. A dead battery can manifest itself in many forms: It may not accept a charge (this particular symptom may also indicate a problem with the logic board), the computer may not recognize the battery, or the battery may be recognized as charged but fail to power your computer when the AC adapter is unplugged. We sell replacement batteries.
The MacBook replaces the iBook, with a Intel processor, magnetic Magsafe power connector, integrated iSight camera, and 13.3" widescreen display.
Flashing question mark on startup
The computer displays the flashing question mark when it can't find a bootable operating system. This could be because your OS is corrupt, the computer doesn't have enough RAM, or your hard drive is failing.
Bad operating system
Try booting off an OS CD. Run Apple's Disk Utility and try to repair the disk. You could also try Alsoft's DiskWarrior. If this fails, reinstall your operating system. If you can, erase the hard drive prior to reinstalling the OS.
Bad hard drive
The hard drive may have been erased, corrupted, or damaged. If the hard drive has been erased, format it as HFS+ and reinstall your operating system back onto it. If it is corrupted or damaged, you need to replace (Core Duo or Core 2 Duo) it. Failing hard drives can display intermittent data corruption prior to failing completely. They often gradually get louder and start to click. If your hard drive is making abnormal clicking noises but still works, back up your data immediately and replace the hard drive. Any of our (2.5”)9.5mm SATA hard drives will work in your computer.
Bad hard drive cable
This part fails relatively frequently on the 13" Macbook Pro (Mid 2012), and relatively rarely on other models. If you have the Mid-2012 model MBP, you may want to pursue this before attempting a hard drive replacement, as the cable part is inexpensive and easy to replace.
Not enough RAM
This is quite rare. If you have insufficient RAM for your computer to boot the operating system, you may get the flashing question mark. Installing more RAM (Core Duo or Core 2 Duo) or downgrading to an older operating system will fix this. You need 128 MB RAM to run OS X 10.0-10.4, and OS X 10.5 requires 512 MB RAM.
My screen looks black, but I can see faint graphics on it
The screen is very dark, but everything else seems to be running. If you get in close with a flashlight, you can usually see the image faintly.
Backlight Issues
If your backlight isn't working, the inverter may be bad. Other parts that may be bad are the display or the logic board. If your backlight fails intermittently while moving the display, the problem is with the inverter cables. Otherwise it is impossible to test for damaged parts without replacing them one by one. If you are comfortable taking apart the display assembly, replace the display inverter first, then replace the LCD. If you are not comfortable with this, you can replace both parts at once by replacing (Core Duo or Core 2 Duo) the display assembly (Core Duo, Core 2 Duo, or Santa Rosa/Penryn). If this still doesn't solve your problem, you need a new logic board.
The trackpad and keyboard don't work
The computer boots, but the trackpad and keyboard do not work, and USB devices (such as a mouse) do not work.
Faulty Logic Board
This is uncommon, but it does happen. The problem arises as a result of the design of the MacBook. The section of the board with the ports and the section near the fan slot are grounded via the metal shield on the lower case. Screws in these areas complete the ground circuit for the logic board. If a logic board is tested while not in the case with these screws installed, the result can be a short in the logic board. When this happens, the trackpad, keypad, and input devices do not work. The only solution is to replace (Core Duo or Core 2 Duo) the logic board.
None of the above
Nothing above matches your problem, or you've tried a solution suggested above, but it didn't help.
If you lose firewire, USB, audio or ethernet, the only thing to blame is the logic board. Because there are many components of the logic board, numerous possible symptoms indicate logic board failure. Any one of these components can fail and leave the others intact. If you lose the use of another component of your computer, such as the display, battery, or even power, and replacing the apparently non-working part didn't fix the problem, it is possible that the logic board may need to be replaced (Core Duo or Core 2 Duo).
Luke Soules
107 855 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:072 955crwdne2935297:0
crwdns2944067:063crwdne2944067:0
My computer will run for about 10 minutes after the power adapter is unplugged but then it will shut off. Do I have a bad battery?
jcrandall - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Sounds like you do have a bad battery. How old is your computer? also I would try doing a PRAM reset and an SMC reset. https://thenextweb.com/lifehacks/2017/06... But leaning towards bad battery.
Timothy Cocores - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have studied the disassembly routine quiet precisely and think one can do it really itself, I mean to disassembly the MacBook Pro. But there is still a open question for me left. Logical spoken, to reassemble the hole MacBook Pro is just the reverse way how to disassemble it.
Okay so far so good concerning the clips and screws, but how do I fix the "protecting tapes" and "sheet" on the keyboard connection etc.?
Do I need a special glue?
Do I leave them of?
It would be very helpful, if I can have a hint ore even some further pictures "how the reassemble" the protecting parts "tapes" and "sheet"!
Godfredolo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My Mac need to warm up(after press Power button it will run but screen is black) for about 10~15 mins before it can startup.
Will Faulty Ram cause this problem?
KENGY - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hello,
I have a Macbook white 2.0 late 2006 model (core 2 duo), 2GB 667 MHz DDR2 SDRAM, OS X 10.4.11.
Since early days it is not restarting when I choose too. Well at the beginning it used to restart from time to time, and now not at all. I am normally force shutting it by that long press hold on power button, and then I power it back up.
Now, at these few times that it is surprisingly restarting, it's not coming up with airport on. Meaning, the signal/symbol of the airport/wifi, is not there, and it can't detect a network at all :-)
So I normally shut it down again, but properly, and then up again, and when I make shore that the airport is there, and I simply continue working :-)
Never checked this thing in a lab, did all different kind of test and updates, checks, repairs and tricks... but nada!
It works fine for last 2 years and half (except heating and a slow cooling fan, and some slow performance from now and then, and those cracks in the the body and the battery life... well I guess it is simply tired, really it's not a complaint :-) :-) :-)
from time to time I am checking if if someone came across with that kind of problem, and what would be a solution, but I did not find.
Well I guess i need to replace something, and i would love the self home made solution :-) I guess I also want to know if I am hurting the poor guy by force shutting it down all the time.
Bueno, many thanks in advance if you take your time to answer that (even read that), cheers, long living and prosperity.
S.
perfecto - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 97
crwdns2959996:0crwdne2959996:0 178,674
