crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Keyboard not working properly
The keys on the keyboard won't respond
Keyboard/Keys Not Responding
The keys on your keyboard won't respond or appear to be broken or missing. Replace the keys, if issue continues try to replace the whole keyboard. Click here for replacement video.
Faulty Keyboard
If the entire keyboard fails to respond, try replacing it with this guide.
Faulty Keys
When keys can't be pressed, there may be something below the physical key holding it up. To fix this, first try taking off the key itself using a prying tool, if key cannot be removed from the front of the device the back cover might have to be removed and the whole keyboard might have to be replaced. Heres a tutorial on how to replace the keyboard.
Keys Are Missing
If keys on the keyboard are missing, replace them by contacting the MSI customer service department 1-626-271-1004
Unable to connect to the internet
Not connecting to the Wifi.
Faulty wifi connection
Wifi is not connected or it is not working. First try using Windows troubleshooting, check the airplane mode is not on, if problem continues call the MSI support team. 1-626-581-1551
Limited wifi access
The wifi connection has limited access. First try disconnecting the wifi and reconnecting it. Also, make sure that the wifi access point is set to home instead of public. If it did not work you will need to reinstall the wireless driver after removing the old drive. Click here for a quick troubleshooting video.
Wifi is not picking up the internet point
The Wifi is not detecting access points. try the Windows troubleshooting steps, if it did not work try to reinstall the wireless driver after removing the old drive. Which can be downloaded from the MSI support website and a guide can be seen here
Black screen
Display is not working.
Faulty Screen Resolution
If a user is experiencing an issue with the screen leaving lighter spots on a darker background then he/she can identify this as it has been a common issue due to the extremely high back lights of this computer. It appears that there is no solution for it as of now until IPS decides to improve the technology. You may have to contact the manufacturer at 1-626-271-1004. If your screen is damaged, follow this guide.
Microphone not responding
Distorted sounds, connectivity issues.
Faulty Microphone
Internal microphone issue can be resolved by using an external microphone, if problem persists contact manufacturer to resolve issue.
Sound recording is suddenly muted while using Skype or online games chatting.
Please download and install Realtek Audio driver version from MSI GE62 2PC Apache. Before you install the new driver, please remove the old audio driver using Windows Control Panel. Click here to download driver.
Faulty External microphone
Try unplugging the microphone and using a different one to see if problem persist, make sure the port is not obstructed by anything if issue continues, Uninstall the Realtek driver and use the Windows driver. Go to this link to download the Realtek driver.
