Start with the bottom of the laptop facing up.
Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
Remove the bottom plate by pulling away from laptop
Remove the screw holding down the battery with a PH1 screwdriver.
Pull out the battery.
Open the laptop up as if you were going to use it.
Wedge a spudger in between the screen bezel and work it around to separate it.
Remove the screws holding in the screen at the corners with a PH1 screwdriver.
Remove the bezel from the screen.
Remove the two screws located at the bottom of the screen using the PH1 screwdriver.
