Webcam Doesn't Register when Plugged in
Once the webcam is plugged in, the software doesn't appear on the computer.
Bad USB Port
The webcam may not register because the USB port is the problem. There can be something as simple as dust in the port or the connectors within the port are damaged. In either case, try another port before taking the device apart and see if the webcam registers.
Incorrect driver is Being Used
If the proper driver is not downloaded, your computer may not pick up the webcam. The driver supplies your computer with the necessary software in order to run the webcam's program. To find the correct driver, go to the Logitech website and download the correct driver.
Damaged USB Adapter
If you've tried every USB port and installed all necessary drivers, it is possible the webcam's adapter is the problem. The wire might be cut or frayed or the connection to the motherboard may be faulty. Follow this link to replace the adapter.
Doesn't Turn on but Registers on Computer
The webcam shows up on the computer but doesn't turn on.
Power button is Defective
Even after pressing the power button several times, the webcam doesn't turn on, the button chip may be broken and need replacement. To replace the chip, click here.
Broken Motherboard
If the previous solution doesn't work, the motherboard of the device could have a faulty connection causing no power or information to go to or from the computer. This link will show you how to switch out the motherboard.
No Sound is Heard
The device registers and turns on but nothing can be heard.
Video is Seen but No Sound
If you get video footage, but no sound can be heard, the volume on the program could simply be muted. Unmute the volume to have high-definition surround sound. Also, be sure to check your computer as well before delving into your webcam.
Internal Hardware Problem
If turning up the volume does not help, the internal hardware may be the issue. The wire connecting the microphone to the motherboard may have come loose or simply needs to be replaced. Reach the microphone by following this link.
Sound but No Picture
You can hear the other person but you can't see them.
Camera is Damaged
It is possible that sound works just fine but you do not see any video feed. This is possible because the connections or the camera itself is damaged. If this is the case, follow the camera replacement guide here.
Faulty Motherboard
If the lens isn't the problem, the motherboard may be defective. You can find directions to replace the motherboard here.
Cory Davis
crwdns2935283:004/14/13crwdne2935283:0
236 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-34, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 12-34, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S12G34
crwdns2935297:096crwdne2935297:0
crwdns2936753:030crwdne2936753:0 63
crwdns2959996:0crwdne2959996:0 12,875
