crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Brake Pedal Too Stiff
The pedal is difficult to press fully and is unable to give proper feedback in the game.
Pedal is Incorrectly Calibrated
  1. Update the device’s firmware in the Logitech G-Hub
  2. Press the Windows + R key to open the command box
  3. Type joy.cpl to open the Windows Game Controller Settings
  4. Select the entry for the gaming wheel
  5. Press CTRL + SHIFT while clicking Properties
  6. Go to the Settings tab and click Calibrate
  7. Follow the calibration instructions then test the wheel afterwards
  8. Set pedal sensitivity in G-Hub
  9. Check in-game settings
  10. Check with different games or PC to see if the problem persists
  11. Check the pedals
  12. Optimize pedal-facing position
Paddles Not Shifting
The paddles do not shift into the proper gear when pressed.
Improper wire connection
  1. Disconnect the wheel from the PC/ Game console and power outlet
  2. Disconnect the pedals, power adapter, and shifters from the wheel
  3. Reconnect the pedals, power adapter, and shifters to the wheel after about 15 seconds
  4. Connect the wheel to a working A/C outlet and USB on the PC/ Console
Logitech G-Hub not recognizing the Wheel is plugged in
With Computer already ON, but Logitech Gaming Software NOT running,
  1. Connect all wheel/pedal/shifter components to each other.
  2. Plug power for the wheel/pedals/shifter into a wall outlet or power strip.
  3. Start the Logitech Gaming Software, and give a second for it to fully load.
  4. Plug in the wheel's USB cord to the Computer, and let G-Hub recognize the wheel/pedals/shifter. G-Hub will calibrate the wheel's left and right turn, and put the wheel at center position.
  5. Set G-Hub settings to "Default" settings. (First-time setup only, after first setup, you can ignore this.)
No Feedback on Pedals
When the pedals are depressed and there seems to be no response.
Improper wire connection or pending update
  • Turn the wheel and then off again
  • Disconnect the Wheel from the PC/ Game Console and Power Outlet
  • Disconnect the Pedals, Power Adapter, and shifters from the wheel
  • Reconnect the Pedals, Power Adapter, and shifters to the wheel after about 15 seconds
  • Connect the Wheel to a working A/C outlet and USB on the PC/Console
Software Not Up to Date
  1. Download Logitech G-Hub
  2. Connect the Wheel to the Computer you will be using
  3. Ensure that the latest drivers are installed
Steering is Not Working While the Wheel is Turning
The wheel does not turn in tandem in the game.
  1. Check your power source, the wheel gets power from the power adapter.
  2. Check to see if any damage to your cord could be hindering power.
  3. If the LED light is on but turning the wheel still does not affect the game it may be an issue related to the internal components such as the motherboard or internal wiring.
Improper Drivers Installed
  1. Uninstall Logitech G920 driver, unplug USB cable from computer
  2. Uninstall Logitech G-Hub
  3. Restart Computer
  4. Install Logitech G-Hub from Logitech website
  5. Restart Computer
  6. Plug in the G920
  7. Click the popup saying Click here to install latest firmware for G920
Motherboard/Internal wiring malfunction
  1. Unscrew the screws on the back and front of the steering wheel to expose the internal hardware.
  2. Gently unscrew the screws that hold the motherboard in place.
  3. Replace the motherboard and make sure that the board is lined up properly.
Buttons Not Responding
When the buttons are being pressed in-game, the game does not seem to respond as expected.
Pending update or wireless connection error.
  1. Open the start menu and type ‘controller’.
  2. Click on the ‘Set up a Controller or Gamepad’ option.
  3. Right-click the name of the wheel and open Properties.
  4. Push each button on the wheel to see if the window responds to your inputs.
  5. If some or all of the buttons do not respond, reinstall the drivers for the wheel.
  6. If all of the buttons respond, try checking the settings in-game to see if something is wrong.
Faulty internal connections
  1. Gently unscrew the screws holding the top of the steering wheel in place.
  2. Check to see if there are any obvious malfunctions.
  3. Check that all internal connections are properly connected.
  4. If reattaching the unconnected wires does not solve the buttons not giving feedback, replace buttons with new ones.
Tristyn Dolan
crwdns2935283:009/12/23crwdne2935283:0
312 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 2-1, Harold Fall 2023 crwdns2935289:0University of North Texas, Team 2-1, Harold Fall 2023crwdne2935289:0
UNT-HAROLD-F23S2G1
crwdns2944067:014crwdne2944067:0
Wheel is unable to calibrate and the white light is blinking rapidly. Any suggestions?
Jeff Bendel - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have the same issue, during calibration. Wheel stops working and white light blinks rapidly. I will post a link to a video I took. Calibration issue video
Westin McHaney - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I'm having the exact same issue somebody help!
Vianth Naidoo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
everything works on my g920 but when i turn right the buttons stop working and the white light turns off. I have tried unplugging every cable and replugging the power supply but nothing is working. Can someone help
Crippled Dorito - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hello all the buttons work but the steering wheel doesn't. Can anyone help my son please?
Joshy8511 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 20
crwdns2936753:07crwdne2936753:0 86
crwdns2936753:030crwdne2936753:0 440
crwdns2959996:0crwdne2959996:0 31,489
