crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If your Lefant M210 is navigating erratically and/or missing cleaning areas, there may be an issue with its sensors or mapping system. Try these quick troubleshooting steps to fix the problem.
Sensors are Dirty
Dust or debris on the sensors (especially the cliff sensors) can confuse the vacuum, causing it to change direction unexpectedly or get stuck. Use a dry, lint-free cloth to gently clean all sensors on the Lefant M210, making sure to wipe the bottom and sides.
Hair and Debris In Tires
Clean any hair and debris from the tires to ensure they turn properly. If hair is too tangled, you may need to cut it out. For easier access to the entire wheel assembly, you may also want to follow the wheel replacement guide.
Too Many Obstacles and Clutter
Random objects or clutter around the cleaning area can lead to erratic navigation. Make sure the area you intend to clean is clear of any small to medium-sized obstacles. This could include loose cables or household objects the robot might push or collide with.
Firmware Is Out of Date
Sometimes a firmware update will resolve navigation issues. If you haven't downloaded the app, use this link to add the app to your phone. Open the Lefant app and check if any updates are available. The updates may improve the obstacle detection algorithm, a re-calibration of sensors, and bug fixes in the Lefant M210’s software.
Sensor Failure
If you've tried everything, the sensors may have failed and you will need to replace them.
Adrian pg
crwdns2935283:009/09/24crwdne2935283:0
147 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 2-4, Kershman Fall 2024 crwdns2935289:0CSU Los Angeles, Team 2-4, Kershman Fall 2024crwdne2935289:0
CSULA-KERSHMAN-F24S2G4
crwdns2935297:048crwdne2935297:0
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 139
crwdns2942667:0crwdne2942667:0 2,033
