Lefant M210 Wheel Assembly Replacement
crwdns2869540:0crwdne2869540:0: 2,8K
8
51
264
2.831
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: 20 - 40 crwdns2931279:0crwdne2931279:0
This guide provides step-by-step instructions for replacing the wheel assembly on the Lefant M210 robot vacuum.
    1. Lefant M210 Wheel Assembly Replacement, Brush: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lefant M210 Wheel Assembly Replacement, Brush: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn off the Lefant M210 and disconnect it from the charging dock.
      • Flip the unit over so the bottom faces upward.
      • Locate the circular brush assemblies on the left and right sides of the underside.
      • Place the unit on a clean, flat surface to prevent scratching.
    2. Lefant M210 Wheel Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lefant M210 Wheel Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lefant M210 Wheel Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the iFixit Opening Tool (or similar pry tool) under the circular edge of the brush assembly.
      • Apply gentle downward pressure on the opposite end of the tool to lever the brush component out of its housing.
      • Remove the brush assembly completely and set it aside.
      • If replacing both brush assemblies, repeat this process on the other side.
      • Avoid using excessive force, which may damage the mounting clips.
      • Position the new brush assembly above the square mounting peg.
      • Align the square cavity on the bottom of the brush with the corresponding square peg in the vacuum housing.
      • Press down firmly on the brush assembly until you hear or feel it click into place.
      • Gently tug on the brush to verify it is securely seated.
      • The brush should sit flush with the housing and not move when pulled gently.
    1. Lefant M210 Wheel Assembly Replacement, Wheel Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Phillips screwdriver to remove four screws near each wheel.
    2. Lefant M210 Wheel Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Lefant M210 Wheel Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the plastic cover next to each wheel.
      • Grip both sides of the wheel and pull upwards.
      • The wheels of the device require some force to remove.
      • Don't pull the wheels too hard as they are attached to cables and may be damaged if yanked.
    3. Lefant M210 Wheel Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Lefant M210 Wheel Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Lefant M210 Wheel Assembly Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Hold the wheel up and detach the connector to release it from the device.
crwdns2935291:0crwdne2935291:0
Adrian pg
crwdns2935283:009/09/24crwdne2935283:0
147 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 2-4, Kershman Fall 2024 crwdns2935289:0CSU Los Angeles, Team 2-4, Kershman Fall 2024crwdne2935289:0
CSULA-KERSHMAN-F24S2G4
crwdns2935297:048crwdne2935297:0
crwdns2936753:07crwdne2936753:0 51
crwdns2936753:030crwdne2936753:0 264
crwdns2959996:0crwdne2959996:0 2,831
