crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device will not turn on
When pressing the power button, the device will not turn on.
Battery is Drained
Attach charger to the device and plug it into the outlet.Wait a few minutes and the device should light up, indicating that it is charging. If the battery fails to hold the charge for the expected duration see guide for Replacing the Battery.
Bad Charger
If after leaving the phone plugged in for several hours it still will not turn on, replace the charger.
Damaged Charger Port
IF the charger port is damaged see guide for Replacing the Charger Port.
Application crashed
When using an application and it randomly becomes unresponsive or quits running and returns to the home screen.
Application Frozen
Try to go back to the home screen. If still frozen, try to lock and unlock device (Soft Reset). If problem persists, turn device off, wait a few seconds, then turn it back on. Once the device is turned on open the application again.
Unresponsive Device
When the device’s power is on, but it does not respond to commands.Or, when device simply will not turn on.
Overheated Device
Remove device from the sun and let it cool off for a few minutes.
Device Frozen
Try to go back to the home screen. If still frozen, try to lock and unlock device (Soft Reset). If problem persists, turn device off, wait a few seconds, then turn back on. If soft reset does not work see guide for Replacing the Home Button. Once the device is working again close all applications and websites that may be too intense for device.
Touchscreen is not working
Verify that protective cover, or case, is not interfering with touchscreen sensitivity. Perform a soft reset. Identify if operating system is affecting touchscreen functionality. Verify that there are no cracks on the display. If there are cracks on the display see guide for Replacing the Display.
Internet Loss
When unable to maintain a consistent internet connection, or when the connection randomly drops, while wifi connection is available.
Wifi won’t connect
Toggle on and back off from preferred wifi connection. If problem persists, toggle on and back off from airplane mode. Wait a few seconds to ensure that all of the radios are powered off before tapping the airplane icon the second time.
Distorted Audio
If you can hear static noise, or audio quality fails to meet expectations.
Damaged Speaker
See Guide for Replacing the Speaker.
crwdns2935291:0crwdne2935291:0
Craig Lashley
crwdns2935283:010/08/14crwdne2935283:0
307 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 9-1, Leahy Fall 2014 crwdns2935289:0USF Tampa, Team 9-1, Leahy Fall 2014crwdne2935289:0
USFT-LEAHY-F14S9G1
How do you perform a soft reset
Cindy Myers - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
i want my problem i cant find my problem
so please tell my problem solution my problem is my apps is telling they wnt gmail.com but when iam tpeing my gmail thats is try again please tell my problem solution now
Mohd Ali - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 35
crwdns2959996:0crwdne2959996:0 5,940
