The following guide explains how to replace the home button.
Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
Remove the battery and SIM card.
Remove the twelve screws using the Phillips 000 screwdriver.
Remove bottom plate where the charger port is located.
Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
Flip over to the face of the device.
Lift off the glass screen (display).
Remove the home screen button. Replace as needed.
in the step 2, one red ring is in the wrong position.
The ring in the midle at the left side is in the center of the telephone
Tiago - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
