crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device does not turn on
The device remains unresponsive when pushing the power button. Screen remains black
Screen does not turn on
Performing a soft reset may resolve the issue
Any other hardware issue in the screen including the digitizer, wiring, and LCD will require replacing the whole screen hardware piece which includes them all.
Battery is dead
Click Here to go to decreased battery life troubleshooting.
Power Switch Broken
Make sure to hold down the Power button. If device doesn't turn on, it is possible the power switch is broken.
Cracked Screen
If the device's glass screen is scratched, cracked, or not displaying properly, the following repairs may be used.
The screen is broken or cracked
Try testing the touch display. In most cases the device will keep operating normally. If this is the case, then the problem is cosmetic but requires a major part replacement. If planning to replace the glass screen of the tablet, consider replacing the whole LCD screen display since the glass is adhesively glued to the touch digitizer. These steps are detailed in the following guide.
If the device was dropped or has a lot of use, display screen can be broken and not working. A guide to replacing the screen can be found here.
Water Damage
Moisture content can be too high and possibly destroyed the electronic composure.
Device does not charge
When plugged in to charge, the battery icon does not show to be charging. If the tablet has no charge, plugging it in does not cause it to light up or turn on.
Battery Failure
Charger Broken
Tablet chargers are a common area of wear, purchasing a new one may be necessary. The LG G Pad 7.0 uses a micro-USB charger, which can be found cheaply.
Charge-port Loose
Using excessive force while plugging into the charger, or wiggling the charger in the charge port can loosen the connection between the charger and the device. If the charging icon does not appear when plugged in, try to blow in the charge port to reduce possible dust or sediment within the device. If this does not fix the problem, the charge port may need to replaced, per the following guide.
Decreased Battery Life
Device charge does not last as long as preferred. It may consistently display a low charge.
Device has too many features active
There are many small things that drain excessive battery power, and most of these can be fixed within the power settings of the device.
- Decreasing screen brightness will extend life
- Navigate to settings
- Display
- Drag the battery slider to the left.
- Using a live (moving) background (wallpaper) decreases battery life
- Display
- Home Screen
- Wallpapers
- Select a non-live wallpaper
- Turn of Wi-Fi Usage - only helps if there is no within range
- Swipe down on the top status bar
- Tap the Wi-Fi and/or bluetooth buttons
Device has too many applications running
Many applications continue to run and use energy if not explicitly closed when finished.
Turning unnecessary apps off may extend battery life
- Tap the recent apps icon
- This is the third icon on the bottom, looks like a square
- Swipe the app you want to close to the left or the right.
Battery is improperly calibrated
A soft reset can can reset the battery calibration, and in some cases may increase battery life, while not erasing any content.
- Press the power and volume down key
- Hold the buttons until the LG splash screen appears
- The tablet will automatically restart.
Charger is not working
If the charging icon is failing to increase or only increases to a certain amount, it is possible that the charger is working incorrectly. This can be tested by using a different charger. If the phone charges normally the charger is at fault. At this point it is suggested to buy a new charger.
Battery has gone bad
If all the previous steps have failed to increase battery life, the battery has probably started to fail. This happens with time, and is an easy fix, but requires the purchase of a new battery. A replacement guide can be found here.
Device slows and freezes
Characterized by the device freezing temporarily, performing slowly, not allowing the download of new apps, or stopping working abruptly while in use
SD Card is worn, possibly with decreased read/write speed
- Swipe down on the settings bar
- Press settings
- Storage
- Unmount SD card
- Ok
- Remove SD card
Too many background applications and processes are running
Even if apps are not open, they can still be running, slowing down the internal hard-drive of the tablet. Make sure all non-active apps are closed.
- On the bottom home screen, press the recent tabs icon
- It should display recent apps used
- Press CLEAR ALL
Alternatively, a soft reset may be performed, This process restarts the device without losing any personal data.
- Press and the power and volume down key
Device has low memory
- Tap "All apps Icons" from the home screen.
- Storage
- Look at available storage in the internal storage section to determine if the device has low memory. Below 500 megabytes is a sign some programs should be deleted.
Application cache is full
This doesn’t remove personal settings such as login information and high-scores, but it does clear unwanted memory and space within the device.
- Press settings
- Apps
- swipe left to the ALL tab
- Click on an app
- Press clear cache
- Repeat for other apps.
Software Needs to be Updated
It is always important to keep device software up to date. Check the app store to see if the device has any available updates.
Device not connecting to Internet
Unable to access the internet, or many apps, usually the device will inform you when it is failing due to internet connectivity
Wi-Fi router is not working correctly
All devices need clear and proper Internet access. Poor connectivity may not be the device, but the internet source. Check the Wi-Fi router or hotspot.
Wi-Fi capability is turned off
Slide down home screen and make sure Wi-Fi button is highlighted blue on the top left section of the screen.
Alternatively, go to settings and make sure the device is connected to the proper receiver.
Wi-Fi receiver is faulty
If Wi-Fi is still not functional, the Wi-Fi receiver may be broken and may need to be replaced.
Device speaker broken
Speaker or headphones do not play sound during videos or when playing music.
Broken headphones
An easy way to eliminate the problem is to make sure the headphones work in another device. It is also possible to blow the speaker on the device.
Broken speaker
If listening at maximum volume, it is possible to blow the speaker on the device. It will need to be replaced.
Broken Audio jack
If sound comes from the loud speaker but not the headphones it is most likely a broken audio jack. It will need to be replaced
crwdns2944067:011crwdne2944067:0
if running the screen on all the timf will it hurt it
charles - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have done all the updates but if I try to read a story in Facebook it kicks me out back to my news feed. It freezes slot on some games and kicks out of it and restarts. I don't have this problem on my LG 5 phone. What can I do to fix this cause I'm not happy with it and I'm stuck with it for two years?
cowgirltoby - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
First sd cards stopped loading after a software update and now shortly after a new software update it's rejecting the sim. How can I fix it? Nothing here addressed any of these problems.
Samantha Milburn - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I am still having the problem of the screen not turning on but still vibrates and my alarm still goes off ive tried reseting it a couple of times and its still black i need some suggestions on what else to do
Maria Barrios - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
my tablet touch does not work … can you repair my tablet touch .. plzz do something for my lg tablet 7.0
amirkhawn - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
