crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
If one or more keys on your keyboard are not registering when pressed, this troubleshooting page may provide possible solutions.
The Mechanical Switch is Not Fully Seated
If you recently removed the keycaps, there is a chance that the mechanical switch came out with the keycap. When reinstalling the switch, it may not have been pushed all the way. A loose connection can prevent the keyboard from registering the key press.
Make sure the switch is fully seated by removing the keycap with a keycap puller to inspect the switch. Check to see if the switch is sitting flush with the keyboard plate or if there are gaps, as that could indicate it is not fully seated. Push down on the switch until you hear or feel a click. Test the key again, and if it still fails, remove and reinstall the switch itself to ensure proper alignment. Refer to this guide for instructions on accessing the mechanical switch.
The Mechanical Switch is Damaged
A mechanical switch can stop working for several reasons, including liquid damage, dust or debris inside the switch, or internal component failure. If the switch feels rough, sticks, or has unusual resistance when pressed, it may be damaged.
Remove the keycap with a keycap puller and check for sticking, grinding, abnormal resistance or visual damage/debris. Do not open or clean the switch without experience, as it can be easily damaged and made worse. An easier method would be to replace it. Use a switch puller to remove the switch from the hot-swap pocket and install a new compatible mechanical switch. Test the key again. For detailed instructions, follow the Keychron K10 Max Wireless Mechanical Key Switch Replacement guide.
Hot-swap Socket or PCB Contact is Damaged
It's possible the pins on the hot-swap pocket are bent, or the contact pads from the PCB are worn. If this is the case, the keyboard may fail to recognize inputs.
Remove the switch and inspect the metal pins for damage or corrosion. Also, inspect the hot-swap pocket pin holes for damage or debris. Try replacing the switch with a known working one. If the new switch doesn't work, then it can be confirmed to be a problem with the socket and not the switch.
If the socket is loose or damaged, the keyboard will need to be opened and the PCB inspected for damage. From there, the how swap socket will have to be taken out and replaced.
Firmware or Software configuration Issues
The firmware could be out of date, set incorrectly or the keyboard could be set in the wrong mode.
Toggle between Bluetooth and wired mode to ensure the keyboard is set to the right one. Connect the keyboard via USB-C and check whether the keys work in wired mode if you are having trouble in Bluetooth mode.
You can also try resetting your keyboard to factory settings. This can be done by turning the keyboard on and holding Fn+J+Z for 4 seconds. Wait until the backlight flashes red for 3 seconds, indicating the reset is complete.
If none of this works, the firmware might be corrupted or out of date. Connect your keyboard via USB-C. Download the K10 Max firmware from the Keychron website here.
Richard Witkowski
crwdns2935283:003/23/26crwdne2935283:0
595 crwdns2915208:0crwdne2915208:0
Purdue University Northwest, Team 7-8, Dieterle Spring 2026 crwdns2935289:0Purdue University Northwest, Team 7-8, Dieterle Spring 2026crwdne2935289:0
PNW-DIETERLE-S26S7G8
crwdns2936753:030crwdne2936753:0 100
crwdns2959996:0crwdne2959996:0 443
