crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Microphone isn't producing sound
The microphone just will not make sounds when the buttons are pressed
Make sure on/off switch is turned to on
The device's switch has 3 settings: Demo, Off, and On. The On setting is the furthest to the right. Make sure the switch is in that position when using the device.
Battery issues
Batteries inserted improperly
Follow the figure below the battery in the slot in which the battery lies. Namely, the negative, or bottom, end should be placed up against the spring. The positive end, with the notch, should face the side opposite the spring.
Dead batteries
This device takes uses 3 AAA batteries for power. If the device is on but not making sound or the sound is weak or spotty, the batteries could be dead. Remove the back panel using a screwdriver and remove the dead batteries. Replace them with 3 new AAA batteries.
Buttons are sticking
If one of the three buttons on the front of the device is sticking, that could cause a lack of sound.
This requires the device to be opened up and the buttons to be adjusted, refer here for that problem.
On/off switch is broken or jammed
It is possible that the On/Off Switch could be damaged, broken, or jammed. It needs to be replaced for the device to work properly; refer to this guide to repair it.
Speaker is dead
The speaker of the device could be dead and need replacement. This requires the device to be opened up, refer here for help replacing the speaker.
Printed circuit board is bad
The printed circuit board on the device could be faulty or worn which requires the device to be opened up and the board to be replaced, refer here for help replacing it.
crwdns2935291:0crwdne2935291:0
Mike Seyman
crwdns2935283:010/19/14crwdne2935283:0
437 crwdns2915208:0crwdne2915208:0
Baylor, Team 4-1, Williams Fall 2014 crwdns2935289:0Baylor, Team 4-1, Williams Fall 2014crwdne2935289:0
BU-WILLIAMS-F14S4G1
crwdns2935297:048crwdne2935297:0
crwdns2936753:030crwdne2936753:0 50
crwdns2959996:0crwdne2959996:0 494
