Popping Sounds in the Audio
The recorded audio from the microphone has loud crackling or popping sounds.
Loose/Broken Cable Connection
Ensure the USB to USB C cable is plugged in fully to the base of the microphone. The microphone will light up, signifying there is sufficient power being received. If the problem persists while the cable is fully plugged in, the line could be faulty. It would help if you then considered buying a replacement USB to USB C cable.
Faulty Auxiliary and USB Ports
It's possible that the auxiliary and USB ports of the microphone are faulty. The auxiliary and USB ports will be connected to an I/O board inside the microphone. To replace these ports you should follow this guide.
Faulty Pop Filter
The microphone has a metal mesh on its outside, which inside is red foam. This foam is the device's pop filter which shields wind, air blasts, breathing, and other sounds which may cause loud pops in the audio. You can try to replace this pop filter using this guide.
Too Close to Microphone
Make sure to distance yourself from the microphone. Being too close to the microphone will increase its detected audio. Spacing yourself several inches away will help to decrease the number of unwanted sounds. This spacing technique may help to eliminate the popping and cracking sounds, saving you the time of replacing any components.
No Illumination
The RGB microphone is not lighting up.
Incorrect Settings
When using the HyperX QuadCast S microphone, you may control the RGB settings through the Ngenuity software. Some of the time the settings in the software will have the led turned off, disabling any illumination. Download the software from the official HyperX site, and renable the illumination.
Imbalanced Microphone Sensitivity
The microphone's noise level or clipping point is distorted.
Faulty Driver
To reduce the amount of background noise picked up by the microphone, follow the following steps.
  1. Search for Control Panel on your PC.
  2. Now select Control Panel and click on the Hardware and Sound option.
  3. Next, choose the Sound option.
  4. Click on the Recording tab.
  5. Right-click the HyperX Quadcast S microphone, and click Properties.
  6. On the Levels tab, set the microphone to 100.
  7. Click Ok to save settings.
Incorrect Levels
To correct the HyperX QuadCast S level settings, follow the following steps.
  1. Go to Control Panel.
  2. Click on Hardware and Sound.
  3. Select Sound.
  5. Right-click on the page and select Show Disabled Devices.
  6. Right-click the HyperX QuadCast S microphone and click Enable.
  7. Right-click it again and select Set as Default Device.
  8. Right-click and click Properties.
  9. Click the Levels tab, then drag the volume slider to 100.
  10. Click OK.
For further information use the official Microsoft Customer Support Guide.
Faulty Polar Pattern Knob
It's possible that the polar pattern knob may not be switching the microphone channels properly. To replace the faulty polar pattern knob, follow the steps using this guide.
Microphone Isn't Picking Up Audio
The microphone is not recording audio input.
Permissions Not Allowed
You may need to allow permissions on certain apps to record audio from the HyperX QuadCast S microphone. To do so, follow these simple steps.
  1. First on your PC select Start.
  2. Click on Settings.
  3. Access Privacy.
  4. Go to Microphone.
  5. In Allow access to the microphone on this device, select Change.
  6. Make sure the device is turned on.
  7. You may now access and change the settings for different apps on your PC.
For further guidance and support follow the official Microsoft Customer Support Guide.
Microphone is Muted
To mute the microphone, touch the "Tap-To-Mute Sensor" (the microphone mute symbol) on the top of the microphone. This will turn off the microphone's illumination, muting the microphone. If you notice the microphone to not pick up any audio, make sure that the illumination is on showing you're unmuted.
Faulty I/O Board
The I/O board provides the interface and access to the auxiliary and USB ports for the device. If this I/O board is faulty, no power will be received by the device, not allowing it to function properly. You may need to replace this board using this guide.
Low/Quiet Audio
Microphone audio is too low, or silent.
Faulty Audio Sensor
To capture the best audio make sure the microphone is sitting in a horizontal position and the HyperX logo is pointing toward you. This will allow the audio sensor to correctly pick up any audio input.
Another solution is using different settings on the Microphone. You can change the sensitivity settings by adjusting the polar pattern knob on the back. Or you may change the gain of the microphone by using the gain control knob.
Faulty Gain Control Knob
The gain control knob is responsible for the volume level of your microphone's input audio. If the audio that's being recorded is too loud or quiet it could be because the knob is faulty. If so follow this guide.
Microphone Will Not Mute
Microphone audio cannot be muted.
Faulty Tap-To-Mute Sensor
The Tap-To-Mute Sensor is responsible for muting the HyperX QuadCast S microphone. If this sensor is faulty, you will not be able to mute the audio being recorded. To replace the tap-to-mute sensor, follow this guide.
Nathan Arruda
crwdns2935283:010/25/22crwdne2935283:0
765 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 4-1, Sinclaire Fall 2022 crwdns2935289:0UMass Dartmouth, Team 4-1, Sinclaire Fall 2022crwdne2935289:0
UMASSD-SINCLAIRE-F22S4G1
se desconecta de manera inesperada y cuando vuelve a conectarse la voz suena super aguda y distorcionada
Flor azul Espinoza rojas - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 20
crwdns2936753:07crwdne2936753:0 100
crwdns2936753:030crwdne2936753:0 418
crwdns2959996:0crwdne2959996:0 42,337
